Reply
Thread Tools View Mode
Old 22nd Dec 2016, 13:47   #1
arg-ist
Multimodder
arg-ist's Avatar
arg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyan
The First Double Sided ModArt QUADRAD Custom Case In The World.Update 23.03.2017
ModArt ByLevon &arg-ist Collaboration
The First Double Sided ModArt QUADRAD Custom Case In The World /
With Four Loop ,Four Radiator,Four reservoir,Four Pump.
Latest situation of the worklog
My friend Levon offered to make a PC Case , that was a little different, big and extremly.
He wanted to make a case with square Outlook(Quadrat)
He wanted to make watercooled case with 4 loops by using 4 rads, 4 pumps ,and 4 reservoir.
For this reason we gave to the case the name QUADRAD .
Our aim was to use this box in the future with different systems
We were going to do it from scratch, not by modifying a standard case.
After some sketches, we decided to make a case like this , with design of Levon.
The frame of the case is designed with a cross-section with 45 degrees broken corners.
Main equipment will be as follows
Mainboard: Z170A-XPOWER-GAMING-TITANIUM-EDITION
https://www.msi.com/Motherboard/Z170...M-EDITION.html
MB monoblok
EK-FB MSI Z170A XPower TE Monoblock
RAM blok BİTSPOWER Universal RAM Module
Video card : 2x MSI GTX1080 SEA HAWK EK X 8GB GDDR5X 256Bit DX12 Nvidia GeForce
https://www.msi.com/Graphics-card/Ge...#hero-overview
PSU CORSAİR AX1500i,
http://www.corsair.com/en/ax1500i-di...modular-psu-eu
RAM
Vengeance® LPX 64GB (4 x 16GB) DDR4 DRAM 3600MHz C18 Memory Kit - Black (CMK64GX4M4B3600C18)
18 x HD120 RGB LED High Performance 120mm PWM Fan with Controller
2 x CORSAIR Lighting Node PRO
4 x Neutron Series™ XTi 960GB SATA 3 6Gb/s SSD
the front and rear panels and side windows are planned as plain-flap on the plain wings , sides bent 45 degrees outward.
So that 18 cm depth of the normal case , was removed to 30 cm.
We started making a 1/1 carton model , to see what the case would be like in advance.
There are air grids on the flaps and 4 reservoirs on the 4outsides.
arg-ist is offline   Reply With Quote
Old 26th Dec 2016, 14:42   #2
arg-ist
Multimodder
arg-ist's Avatar
When it came out as a case -sized volume, I started to draw vector drawings.
As material came and went between aluminum and sheet metal (steel).
For easy gas welding we used steel.
2 M2 sheets required as material
1.20mm thickness required for steel.
and it weights 2X9.00=18.00 Kg
If we have used aluminum sheet . we must use 2.5 -3.0 mm thickness.
And it weights 13.5 -16.5 kg.
when the gaps are dropped , steel case weihts 12.5 kg
A reasonable weight of 12.5 kg when it is thought that a 900D case is 18.6 kg.
During vector drawings, we decided to make the case not from 4 equal parts, 2 smaller equal parts to upper and lower, 2 larger equal parts to front and back.
The case will consist of the 2 top and bottom parts and 2 front and back panels and 1 motherboard back plate.total 5 parts.
Other than the integrated radgrils on the top a ,there are 4 holes 20 mm in diameter.
To easy fill ofthe reservoirs with fluid.
Panels providing cable connections to the case at the corners
(B) At the top, an ON-OF button with 30 mm diameter and a 22 mm restart button and 2x USB 3.0
(C) There are also two 5.25 for fan controllers close to the top.
(D) At the lower part an HDD power on-of switch.
(A)The front and back panels are equally made so that both sides of the case could be used as the front panel. Ther is no backside panel at this case.
To check the size of the sockets, the cable panel was cut from plexi at laser .
Necessary corrections done
Old 30th Dec 2016, 12:17   #3
arg-ist
Multimodder
arg-ist's Avatar
Prepared drawings were cut in CNC metal laser
And bended with a CNC sheet metal bender.
Bended parts
All parts ,cut and bent ,together in bulk.
Details inside and outside of the front and rear panels
Details of the upper and lower panels
If Porsche has a Show model ...
This our Show model
If she will enjoy the car
I can enjoy too
Old 5th Jan 2017, 10:46   #4
arg-ist
Multimodder
arg-ist's Avatar
The parts were assembled for testing purposes.
To prevent the shaking of the case , 2 bended steel pieces ( at Z shape ) added on the floor and ceiling.(marked)
Then they were fixed to the base and ceiling with welder (punctured)
And the MB backplate screwed . This has increased the stability much more.
Old 5th Jan 2017, 12:21   #5
jojoharalds
Supermodder
jojoharalds's Avatar
jojoharalds has yet to learn the way of the Dremel
This looks very promising ,
can´t wait to see where this is heading !!
keep up the good work
jojoharalds is offline   Reply With Quote
Old 5th Jan 2017, 18:18   #6
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
Great work. I like the card board test.
__________________
Wait, I’ve got an idea, and it doesn’t require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Old 6th Jan 2017, 01:53   #7
Bartacus
Supermodder
Bartacus's Avatar
Bartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming SaiyanBartacus is a Super Spamming Saiyan
Very promising indeed!! Great stuff so far!
Bartacus is offline   Reply With Quote
Old 8th Jan 2017, 18:04   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Looking good! HUGE too. My guesstimation is about 2 foot square. (Maybe just a small cat? )
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 9th Jan 2017, 08:40   #9
Hukkel
James' minion
Hukkel's Avatar
Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.Hukkel is the Cheesecake. Relix smiles down upon them.
Nice idea and execution so far. But dayum 80cm * 80cm is enormous!!!
__________________
Facebook page
Hukkel is offline   Reply With Quote
Old 9th Jan 2017, 14:46   #10
arg-ist
Multimodder
arg-ist's Avatar
Thanks Cheapskate
Of course it could be a smaler case .But;
1- İt was his owner's choice. And it was enough for me with big case!!! 900D.
2- We need a case for 4 loops with
4x360 rad
4x215 reservoir
4X D5 pump
And a classic for me, waterchanels from plexi
Sorry ,what to do , everyone wants from me a big case …
I promise you, I will build a supermini case… for you…
Like this…
Old 11th Jan 2017, 10:40   #11
arg-ist
Multimodder
arg-ist's Avatar
Thanks
jojoharalds Supermodder
Dr. Coin Supermodder
Bartacus Supermodder
Hukkel James' minion
arg-ist
Old 12th Jan 2017, 14:20   #12
arg-ist
Multimodder
arg-ist's Avatar
I/O panel 90 degrees rotated but not like at RAVEN 01 upwards ,
just the opposite , I/O PANEL placed downwards and in the case.
Not to open the side window every time , to connect cables to the MB , special extension cables used
Used cables
The sockets will be moved out of the case, into the corners,
Cables assembled at corners
The cables will be hidden behind the back panel through drilled holes.
cable pas through holes
Mounted sockets and cables
The cables were taken from the holes to the rear
To provide motherboard connectivity for these cables, the cable passthrough channels on the rear panel opened.
Old 14th Jan 2017, 10:17   #13
arg-ist
Multimodder
arg-ist's Avatar
With four bras case feet made on the lathe.
Such a view was provided (without coating andwithout 4mm black delrin feet)
Old 15th Jan 2017, 06:33   #14
Dr. Coin
Supermodder
Dr. Coin's Avatar
Reading though the list of cables you used and I noticed that the TOSlink is gold plated. What is the point of a gold plated optical connector?
Case is looking good.
__________________
Old 16th Jan 2017, 14:19   #15
arg-ist
Multimodder
arg-ist's Avatar
At other cables are required to prevent oxidation.
But I do not know how effective here at optical cable
It can be also a marketing policy. arg-ist
Old 17th Jan 2017, 01:03   #16
Dr. Coin
Supermodder
Dr. Coin's Avatar
Yay marketing
__________________
Old 20th Jan 2017, 12:26   #17
arg-ist
Multimodder
arg-ist's Avatar
İnstead of using a standart Modular I/O Panel like this..
Metal rods were considered
And they are made from brass on the lathe.
The back of the CPU is emptied. With mounting of these bras rods in their place.
The provisional trial board provided the following look
There is free space for a counter nut (red marked )
Old 20th Jan 2017, 22:56   #18
Bartacus
Supermodder
Bartacus's Avatar
Wow, very cool idea with the brass!
Old 24th Jan 2017, 16:03   #19
arg-ist
Multimodder
arg-ist's Avatar
Thank you Bartacus.
Old 25th Jan 2017, 13:05   #20
arg-ist
Multimodder
arg-ist's Avatar
Another new one joined to us at this Project.
My friend Levon became a baby.
Nice to meet you baby…
I will do next Project with you .
Grand father- arg-ist
The new cradle I bought for you
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
