Reply
Thread Tools View Mode
Old 20th Mar 2017, 15:21   #41
bakan
What's a Dremel?
bakan has yet to learn the way of the Dremel
Looking at your work.I want to see more.
bakan is offline   Reply With Quote
Old 20th Mar 2017, 19:29   #42
MellowMods
What's a Dremel?
MellowMods's Avatar
MellowMods has yet to learn the way of the Dremel
Great stuff! Build looks incredible. Where did you get the 250V c14 plug?
MellowMods is offline   Reply With Quote
Old 23rd Mar 2017, 09:24   #43
arg-ist
Multimodder
arg-ist's Avatar
arg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyanarg-ist is a Super Spamming Saiyan
With temporary mounting of plexi water distributors, Cutting and mowing works are finished.
Left distrubutor for MB +CPU+RAM Water blocks
Right distrubutor for Water blocks of GRAPHİC CARDS
Now all parts will go through. Parts must be grinded, sanded. The last check will be made and sent to powdercoatig.
We chose RAL 7015 Slate grey
Because we use powdercoating instead of RAL 7015 auto lacquer, we hesitate to grab this mat gray tone in color
I undertook the construction of the case in this Project
My work has come nearly to an end with the construction of water channels and painting.
After that you can follow HERE what my friend levon can add to the case and do on this case.He must build Hardware,Watercoolingand cable management.
THANKS TO ALL FOLLOWERS.
To see you at a new worklog. arg-ist
arg-ist is offline   Reply With Quote
Old 25th Mar 2017, 10:18   #44
modartbylevon
What's a Dremel?
modartbylevon has yet to learn the way of the Dremel
Case is almost finished.We have prepared the water channels and leak tested. We are preparing case for the paint. It will be painted as soon as we finish our final touches
modartbylevon is offline   Reply With Quote
Old 25th Mar 2017, 21:33   #45
calebkan
What's a Dremel?
calebkan has yet to learn the way of the Dremel
its really great work indeed..gz guys..and its really huge case..I'm following
and
I'm curious about the weight_?how much is the case?seems very heavy
calebkan is offline   Reply With Quote
Old 13th May 2017, 11:35   #46
arg-ist
Multimodder
arg-ist's Avatar
While waiting for the case from the paint, We did the leds of the water channels.
There were channels for led around the plexi water ditributors
LEDs buried in these channels
Later, the LEDs checked.
To prevent light leakage out of the LEDs, The LEDs were covered with black cold silicone on them.
Ready for montage.
Meanwhile, the braas parts came from nickel coating.
Finally came the case from pulver coating.
Nickel coated parts mounted
USB sockets were long
distances was made underneath from 8 mm plexi
In this way, the USBs were fully inserted.
Rear view of the case with mounting of the plexi water chanels
Front view of the case
Details
Test lighting of water chanels without fluid . Rear view.
Front view
We made special parts from the braas to secure the covers.
And we sent them to nickel coating
Time to check the covers
We mounted the back cover
And then front cover
Front cover detail view
Front view of water channel
My work has come nearly to an end with the construction of case and water channels and painting.
After that you can follow what my friend levon can add to the case and do on this case.He must build Hardware,Watercooling and cable management.
Old 13th May 2017, 13:27   #47
kim
Multimodder
kim has yet to learn the way of the Dremel
I really love that case, I said it already, I even don't care of the quality of the pictures, because I enjoy following it so much, but I think such a art piece deserves a great quality final photo shoot...at least...
kim is offline   Reply With Quote
Old 13th May 2017, 14:52   #48
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
That thing is a monster
Love the reservoirs. Love how you've done a double glazing job and sealed the edges in black silicone.
I bet that thing weighs a ton
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 13th May 2017, 19:25   #49
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Looking good.
I always had trouble with silicone. It's like, "It's been 2 months. I'm dry and you can trim me. -HA! HA! I tricked you! I'm not dry at all!"
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 13th May 2017, 20:08   #50
Anfield
Mod Master
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
I'm in love with those water channels
__________________
R7 1800X, ASRock X370 Taichi, 2x8GB Corsair Vengeance 3000 DDR4, ASUS Strix 1080TI OC, 512GB Samsung 950 Pro, 4TB WD Black, EVGA T2 1KW, Lian Li PC-O9WX, EK Supremacy Evo, EK-XRES 140 DDC 3.2, EK-CoolStream PE 360, Ducky Shine 6 (Brown Switches), Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is online now   Reply With Quote
Old 20th May 2017, 17:36   #51
arg-ist
Multimodder
arg-ist's Avatar
At beginning we thought , it would be huge or a hulk…
But the flaps showed it smaller.It is not a huge…
You can compare dimensions with equal cases at Photo.
I have cutted up to 4 Corsair 900D cases until now. I think ı know 900D.
Please try to use 4X250mm Reservoir + 4XD5 Pomp +4X360/60 Rads + 2X big Plexi water chanel
İn a 900D….
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
