Reply
Thread Tools View Mode
Old 30th Dec 2016, 17:34   #1
Gas_designs
Multimodder
Gas_designs's Avatar
Gas_designs has yet to learn the way of the Dremel
Project Hexagon
Hello guys, I want to present my 4th project in the field modding.
This new mod is just on building a Wall Mount, but that will not be fixed to the wall.
I leave for now the imagination, a big screen 40"
Special thanks to Bitspower, and Vincent and LiHan, Mayhems and Mod-One thank you immensely for support.
Special thanks to Danilo Lettieri for his creations cnc
Find her page here:
https://www.facebook.com/pg/creazioniDanilo/photos/
Motherboard: Asrock Z270 Taichi
Cpu: Intel i7 6700K
Ram: Corsair Platinium Dominator 3000MHz DDR4 32GB
Vga: EVGA GTX 1070 Founders Edition
Ssd: Corsair Neutron Series XT 480GB
Cable: [COLOR="blue"]Mod-On
Wb Cpu: Bitspower CPU Block Summit EF (Intel) (Acrylic Top Version)
Wb Vga: Bitspower Nvidia GTX 1080 Reference Acrylic V1
Wb Hd: Bitspower S350 Acrylic Top With Clear Panel
Pump: Alphacool VPP655 - single edition
Top D5: Bitspower Dual D5 MOD TOP (Acrylic Version)
Reseivor: Bitspower Water Tank Hexagon - Acrylic (Limited Edition)
Tubing: Bitspower None Chamfer PETG Link Tube OD14MM-Length 500MM
Fittings: Bitspower Black Sparkle Fitting
Liquid: Mayhems
Radiator: Bitspower Leviathan Xtreme 360 4xG1/4" Radiator
Material for the realization*
Wood - imitation leather - screws varies - glue.
__________________
Facebook Page - Facebook Page -- Facebook Group - Facebook Group -- Project Hexagon - Project Hexagon -- Gas Desk Build -Gas Desk Build -- Dragon Desk - Dragon Desk Build -- Corsair 760T Black & White - Corsair 760T Black & White -- You Tube Channel - You Tube Channel -- Instagram - Instagram
Gas_designs is offline   Reply With Quote
Old 30th Dec 2016, 17:38   #2
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Originally Posted by Gas_designs View Post
Good vision!
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Old 30th Dec 2016, 17:38   #3
Gas_designs
Multimodder
https://www.youtube.com/user/GasDesigns/videos
__________________
Old 7th Jan 2017, 12:16   #4
Gas_designs
Multimodder
Let's start with a gem just made to CNC from Danilo Lettieri.
Find her page here:
__________________
Old 9th Jan 2017, 17:48   #5
Gas_designs
Multimodder
Then finally after a long journey, It came the first material by Bitspower.
=> Stay tuned.
__________________
Old 15th Jan 2017, 14:25   #6
Gas_designs
Multimodder
Some pictures of Bitspower material.
__________________
Old 20th Jan 2017, 17:37   #7
Gas_designs
Multimodder
Start building the big pedestal, wood then hold up the entire mod.
__________________
Old 21st Jan 2017, 16:15   #8
Gas_designs
Multimodder
Continuous with the step of gluing and screwing, the pedestal.
__________________
Old 22nd Jan 2017, 20:42   #9
Gas_designs
Multimodder
Continuous modification of the pedestal, slightly shortening the legs, and smoothing out all the angles, and adding other safety screws.
Then start with the central panel.
__________________
Old 29th Jan 2017, 19:29   #10
Gas_designs
Multimodder
That afternoon I decided to begin to place the trays department, folding and cutting the rigid pipes.
__________________
Old 30th Jan 2017, 20:11   #11
Gas_designs
Multimodder
__________________
Old 11th Feb 2017, 20:46   #12
Gas_designs
Multimodder
Here we are after a week of fever.
I started this afternoon to cut the parts I had traced.
__________________
Old 21st Feb 2017, 14:59   #13
Gas_designs
Multimodder
Some other image ...
__________________
Old 25th Feb 2017, 20:24   #14
Gas_designs
Multimodder
Here we are with a new step.
I adjusted and fixed at the rear of the 5 reservoir, set the pumps and made holes for the bulkhead, and bend the upper tubes of the radiator, with the use of the templates of Bitspower.
Stay tune .....
__________________
Old 27th Feb 2017, 11:19   #15
Gas_designs
Multimodder
This morning I went to finally withdraw the faux leather fabric
He was missing the adhesive to glue it.
__________________
Old 4th Mar 2017, 09:56   #16
Gas_designs
Multimodder
Thanks to Mayhems Solutions, for sending me their fantastic liquid.
__________________
Old 5th Mar 2017, 19:23   #17
Gas_designs
Multimodder
Before and after the first pass of epoxy resin spray, to harden around the panel, before pasting the skin.
__________________
Old 8th Mar 2017, 19:20   #18
Gas_designs
Multimodder
I begin the step of bonding the fabric, with plenty of white glue, in several steps .....
__________________
Old 15th Mar 2017, 10:22   #19
Gas_designs
Multimodder
And after a few days of drying glue you begin to reassemble everything.....
And in the meantime came the new girl: Asrock Z270 Taichi
__________________
Old 1st Apr 2017, 21:42   #20
Gas_designs
Multimodder
[YOUTUBE]
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
