Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 4th Jan 2017, 19:05   #1
neil_b
Supermodder
neil_b has yet to learn the way of the Dremel
W10 clean install question
I have an existing W7 Ent PC, with a 1TB HDD and a couple of SSD's - all running off W7.
I'm going to a clean fresh install of W10 onto the currently empty SSD, and have a couple of questions - my plan is as follows;
1) Disconnect the HDD - its going to be used for apps/games/documents/media etc.
2) Install W10 onto the (currently) empty 256GB SSD (this disk is currently connected, formatted to NTFS and seems to be working fine - do I need to do anything to it prior to setting it as the boot device?
3) Re-connect the HDD after the W10 install is complete.
4) Re-install Office and Photo-Shop onto the newly installed W10 SSD (I really like the speed of response this gives).
So.....
a) Is the above plan reasonable (I know there are different ways of going about this)? Any gotchas?
b) When I re-connect the HDD, will W10 automatically "see" and "pick-up" the HDD or do I have to do anything to make it happen?
Many thanks.
__________________
Case: Fractal R3 CPU: 2600K Mem: 16GB Vengeance SSD: 120GB Vertex 3 HDD: F3/1TB Cooler: H60 GPU: MSI 570 PSU Corsair HX750
neil_b is offline   Reply With Quote
Old 4th Jan 2017, 19:30   #2
neil_b
Supermodder
Additional question - when I go into the BIOS, currently the existing Boot SSD is showing in the boot sequence list, but there is no option to use a Flash Device - how do I get the PC to recognise the Flash Drive as the source for the install, or will it do that anyway if I've already disconnected the old SSD Boot drive?
I also have an MS DVD with a genuine copy of W10, would it be much easier to use the DVD, than faff around in the BIOS trying to get it to recognise a Flash device?
Thanks.
__________________
Old 4th Jan 2017, 20:42   #3
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
The DVD version will probably be woefully out of date. With a USB stick you will get the latest build.
Windows 10 should see your other drive when you connect it but you may have to visit drive management to assign it a drive letter.
Your flash drive would probably be under "Hard Drive BBS options" - have a look there.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 4th Jan 2017, 22:16   #4
neil_b
Supermodder
In the BIOS Boot options I can see something called Generic Reader 2.0 - is that likely to be a Flash Drive capable option?
When you say visit Driver Management to assign a letter, the SSD I'd like to use is currently connected (with no data loaded into it) and it DOES already have a letter assigned, although it doesn't appear in the Boot Drive options list. Will the mobo know about that drive irrespective of whether W10 can see it?
__________________
Old 6th Mar 2017, 17:43   #5
killingit
Minimodder
killingit has yet to learn the way of the Dremel
The BIOS should detect the SSD no problem (considering if you installed it correctly).
killingit is offline   Reply With Quote
Old 6th Mar 2017, 19:38   #6
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
I have done a USB install of windows 10 onto a Samsung SSD 512gb one and it took about 15mins. To have it into windows and useable.
This is from cheap as chips usb3.0 memory stick I brought for about 5. I do not personally have a cd or dvd drive of any kind.
Most flash drives can be booted from, You just select USB in the boot options. Then it will boot from there on most modern boards
rollo is online now   Reply With Quote
Old 8th Mar 2017, 21:22   #7
Broadwater06
Multimodder
Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.
Just to be sure that in the boot options, you opt for 'UEFI' next to whatever your usb stick is and not the other one.
Broadwater06 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
