Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 31st Jan 2017, 17:37   #1
Levelop19
What's a Dremel?
Levelop19 has yet to learn the way of the Dremel
Donít know a reason of pdf issue
I work with Adobe Acrobat 8.0 and I got an error message at opening: There was an error opening this document. Any tipsÖ to repair pdf.
Levelop19 is offline   Reply With Quote
Old 20th Feb 2017, 16:23   #2
afrasiab
What's a Dremel?
afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.afrasiab is definitely a rep cheat.
may be the file is get corrupted. You may find a tool that fixes the corrupted pdfs try to search at google for that tool
afrasiab is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
