Old 8th Feb 2017, 11:16   #1
bundymania
Bastelorakel Industries Worldwide
bundymania's Avatar
bundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremelbundymania has yet to learn the way of the Dremel
Alphacool prototypes
Hi Guys,
Alphacool released some pics of prototypes. What do you think about the products ?
bundymania is offline   Reply With Quote
Old 8th Feb 2017, 23:10   #2
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
They look pretty nice. Fairly clean plexi, not csq type malarky going on anyway. What sort of configurations can the pump top be used on? Can the pumps be separated for instance?
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
