Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 15th Mar 2017, 12:31   #41
stuartpb
Banned
stuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyanstuartpb is a Super Spamming Saiyan
Originally Posted by Kronos View Post
As I am a total noobie I am sorry to say I have no idea what a TX is or 'gains'?
Sorry, TX is the transmitter (radio controller). Gains and expo allow you to fine tune how the drone handles by altering the response to the inputs you make with the sticks, it could be dampening the response or increasing it. Easiest way I can put it. If it's a basic model without a flight controller you have, you most likely won't be able to alter it.
stuartpb is offline   Reply With Quote
Old 15th Mar 2017, 12:47   #42
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
TX = Transmitter; Gain = basically the rate of acceleration, i.e. how far do you have to push the stick in order to make it zoom. You probably can't directly adjust the gain/rates on your transmitter, but it might have a "beginner/expert" setting which effectively does the same thing.
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 15th Mar 2017, 12:48   #43
Byron C
ᴾᵒᵒᵖ
Byron C's Avatar
Originally Posted by David View Post
Is this the right thread to post this?
Bit harsh, innit?!
__________________
Old 15th Mar 2017, 15:18   #44
BrokenJaw
Multimodder
BrokenJaw's Avatar
BrokenJaw has yet to learn the way of the DremelBrokenJaw has yet to learn the way of the Dremel
Originally Posted by creative View Post
you have it already.
If you want to really get into it after flying the micro for a while I would look at getting a decent transmitter first. Something like the Frsky QX7. This can be used with pretty much every quad on the market using a frsky receiver.... From that point it basically boils down to budget!
I think you might be oversimplifying what's required here. The radio receiver (RX) the E010 uses isn't compatible with any 'good' transmitter.
If Kronos was to get his hands on a Frsky QX7, then he would either need to get a transmitter module for the expansion bay (not entirely sure an E010 compatable one exists), or get a Frsky RX.
Getting a RX also means he would need to replace the flight controller, as there is no way to connect an external RX.
The eachine beecore appears to be a neat little flight controller, pretty much designed as a drop in replacement for the E010, and has a built in RX. There are 3 different models to choose from:
DSM (for Spectrum transmitters)
Flysky
FRsky (for use with Taranis and QX7).
However, my advice would be to persevere with the E010 as it is. Get a taster if it's something you want to get deeper into, then splash the cash on a full proper setup. Whether that be a camera platform, or a racer/freestyler.
BrokenJaw is offline   Reply With Quote
Old 15th Mar 2017, 21:31   #45
creative
500rwhp
creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.creative is the Cheesecake. Relix smiles down upon them.
Flysky
Thats why I said its compatible with a frsky receiver. Again this is assuming he wants to do it beyond a micro. 2 areas in this hobby not to skimp on, thats the tx and goggles. I also didnt want to over complicate things for a beginner.
__________________
Fractal Design XL R2 Case * MSI Z97-G45-GAMING LGA1150 * Coolmaster Nepton 280L * Coolermaster V1000 psu * Gigabyte GTX1070 * Intel Core i5 4670K LGA1150 CPU 3.4Ghz 6Mb Cache Haswell * 32Gb HyperX Savage DDR3 * Samsung 850 Evo mSATA * OCZ 128G Vector Series SSD * Seagate 4tb HDD * 3Tb WD Green * 500gb Seagate Hybrid Drive *
creative is offline   Reply With Quote
Old 16th Mar 2017, 09:22   #46
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.Xir is definitely a rep cheat.
Originally Posted by Byron C View Post
...but it might have a "beginner/expert" setting which effectively does the same thing.
It should have two or three sensitivity settings, i've got it on least sensitive, and it's still quite sensitive.
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus VW246H 1920x1080
Xir is offline   Reply With Quote
Old 16th Mar 2017, 13:30   #47
Arboreal
I *am* a Dremel
Arboreal's Avatar
Arboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming SaiyanArboreal is a Super Spamming Saiyan
Lipo Charging?
I now have 2 150mAh 3.7v LiPo packs but neither seem to have a decent amount of charge after leaving them charging for an hour via USB.
The charger supposedly is ready in 50-60 mins, when the light goes off - it hasn't so far
Annoyingly, the replacement charger has the smaller white 2 pin plug, rather than the larger on on the Eachine E010 - I'm not sure what their proper designations are.
Any thoughts on how long to leave it charging?
I'm thinking about getting an Adafruit Micro Lipo charger, as it looks to a properly set up, with a 3 step charge setup - this or something else??
Arboreal is online now   Reply With Quote
Old 17th Mar 2017, 13:20   #48
Kronos
Another grumpy old git.
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
Well after a few days of playing with this I have decided it is not for me. I think for the same reason I cannot use an Xbox or PS controller I find the whole business of knowing where my thumbs should be in relation to the direction of the copter add that to the fact that it really annoys my cat.
Thanks all for your help and advice in my thread on noobie quadrocopters.
Will bung this on the MP.
__________________
Carbide 240/Asus Z170M plus/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/500Gb OCZ TR150 SSD/2 x 256Gb SSD/ 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GTX 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is offline   Reply With Quote
Old 17th Mar 2017, 13:51   #49
Arboreal
I *am* a Dremel
Arboreal's Avatar
Sorry to hear that you & Millie haven't got on with it, at least it wasn't and expensive foray into a potential new hobby...
Old 17th Mar 2017, 13:54   #50
Kronos
Kronos's Avatar
Originally Posted by Arboreal View Post
at least it wasn't an expensive foray into a potential new hobby...
Quite so.
__________________
Old 18th Mar 2017, 14:49   #51
creative
500rwhp
A quick video from last weekend. I was doing some tuning on the 210 after soft mounting the motors. Its not perfect but its getting there...
Also I finally got my lowrider built back up and thats ready to get out in the field, only issue is we are about halfway through an expected 2 weeks of rain...
__________________
Old 21st Mar 2017, 22:52   #52
creative
500rwhp
Just finished updating my transmitter with M9 hall effect gimbals...
Not completely sold on them as yet. Took a lot of adjustment to get them to feel how I like but I will see once I get in the air this week.
__________________
Old 22nd Mar 2017, 13:01   #53
[ZiiP] NaloaC
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
If one were to be bad at controlling their spending, but lies to themselves well enough to justify a €500 budget for a potentially limited life-span purchase, where should one look for a full racer kit?
Basically, is it possible to get into this on a €500 budget (everything, quad, camera, FPV, controller, etc)?
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 22nd Mar 2017, 13:50   #54
creative
500rwhp
yes you can but you will have to shop around. Usual site is banggood (pay for shipping ... dont go the free route!) such as the eachine wizard with a set of box goggles some batteries from hobbyking like turnigy graphines and a charger such as isdt charger ( you will need a power supply for that though) or a b6 charger
Consumables such as props are best bought in bulk and will break! I buy them 30sets (4 in a set) at a time but they do last me a while. Something like dal cyclone v2 with a 3x5x40 blade will suit most 5inch quads.
That should see you in the air. As with all things, price dictates quality but everything can be upgraded from this point if your serious. Also Shop around... I get alot of stuff from america from companies such as Team Legit or here in australia such as my local shop phaserfpv or Nextfpv
Be prepared to do a lot of reading. These things dont fly themselves and often need setting up with flight modes etc which takes an understanding of what the FC does and software it uses, such as betaflight and Blheli suite.
And once you get addicted its very easy to spend.... alot!
My average build price for just the quad is between$500 and $600aud and typically consists of, with a ballpark price:
Frame: current fave is the CraftQuad LoFlo - $195
FC: Omnibus f4 - $50
ESC: Dys XSD30aV2 - $90 for 4
Motors: Im a fan of Brotherhobby t1 2205/2300kv - $100 for 4
fpv cam: Foxeer arrow v2/3 - $50
Vtx: I like the fx800t atm - $75
Antenna: MenaceRc pagoda - $20
Props: Dal Cyclone V2 3x5x40 - $5 a set
This is of course variable depending on what components used Eg, Steele motors are $160 a set or a cheap Qav 180/210 clone frame off ebay for $20.
I currently have 8 quads on my quad wall!
I use fatshark dominator V3's with the laforge diversity receivers, Menace rc pagoda antenna with VAS crosshair patch. My Tx is the Frsky Taranis x9d+ with upgrade M9 gimbals running open tx 2.2 with betaflight PID and smartaudio lua scripts. These were the big purchases but are one thing you only need to buy once and I decided very early on just to get the best at the time.
Also be prepared to crash.... alot... and break things.... alot! My best run I had in an afternoon was breaking 4 quads to various degrees including dunking one in a river but it was one of the most fun afternoons I have had flying as we were all in the same position! Its a local model railway track and everything to hit is either a tree or metal...
__________________
Old 22nd Mar 2017, 17:39   #55
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
FPV'ing with the Rozzers
__________________
Teh unofficial Bit-Tech proof reader and understander of all the necessary hashtags
B1GBUD is offline   Reply With Quote
Old 26th Mar 2017, 23:57   #56
creative
500rwhp
Another weekend of fun and destruction!
My Lowrider is awesome to fly... But I ended up upside down in the only wet part of the field! Fortunately I was able to dry it off and no component damage this time!
Also an example of a lipo failing. This wasnt plugged in and was a healthy battery until it decided to spontaneously explode whilst in hand!
Overall a great weekend... and now, back to the bench!
__________________
Old 27th Mar 2017, 06:42   #57
Xir
Xir's Avatar
...I should stop storing these in their original boxes in the bookshelf
__________________
SN25P
Old 27th Mar 2017, 16:11   #58
morris8809
Supermodder
morris8809's Avatar
morris8809 has yet to learn the way of the Dremelmorris8809 has yet to learn the way of the Dremel
+1 I use two of these to store all of my lipo for safe keeping in my house. http://www.bat-safe.com/web/
They are nothing to play around with. Even undamaged ones can randomly decide to go off one day.
__________________
|Lian-li A70F|Intel® i7 5820k|ASRock X99 Extreme4/3.1
|Crucial DDR4-2400 16GB|Zotac GTX1070|
|Corsair 650HX ||2x 1TB WD Black, 500GB Samsung 840EVO SSD|
|Minecraft server specs: I5 2400, 16GB DDR3, 840EVO 128GB SSD|ASUS P8Z77V-PRO|
morris8809 is offline   Reply With Quote
Old 6th Apr 2017, 10:54   #59
creative
500rwhp
The addiction never ends!
Due to crappy weather and not getting out to fly or anything to fix due to crashes.. I went shopping again!
First up is something to fly inside. I didnt want a tiny whoop with brushed motors due to the life of them and with the increase of micro quads, thankfully the choice has also improved! decided to get a 90mm frame that will do everything its bigger brothers can do!
Size comparison compared to a my Low Rider....
and the motors are tiny 1103/10000kv brushless units....
I am having to mod it a bit to get everything to fit but its getting there. Should be fun on a 2s battery!
I also had another delivery today from CraftQuads...
2 more LoFlow frames with TPU runcam3 camera mounts. I am in love with the way these frames fly so just had to get some more!
__________________
Old 8th Apr 2017, 13:56   #60
creative
500rwhp
So good to be able to get out and fly this weekend....
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
