Reply
Thread Tools View Mode
Old 8th Mar 2017, 13:53   #1
Y.G Casemod
Minimodder
Y.G Casemod has yet to learn the way of the Dremel
Project Virus -Hydra desk case- (Finished)
Hello everyone i'm Yuri.Thanks for accepting me.
I apologize for the mistakes that I will do during the post.
Being new, i'll make sure but I have to learn well to use all the functions have patience.
I would like to present you a mod that I made some time ago.The Virus, based on Hydra deskcase.
And I apologize in advance for my incorrect English.XD
That's where I started ......
Stay tuned.
Y.G Casemod is offline   Reply With Quote
Old 11th Mar 2017, 13:59   #2
arduum
Minimodder
arduum has yet to learn the way of the Dremel
subbed ;D
arduum is offline   Reply With Quote
Old 11th Mar 2017, 15:16   #3
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
Your first post must show work in progress, not just a heap of parts and some rough sketches, as per the rules section.
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is offline   Reply With Quote
Old 13th Mar 2017, 19:59   #4
Y.G Casemod
Minimodder
Of course I know.
Here are the first photos.
Old 13th Mar 2017, 20:03   #5
Y.G Casemod
Minimodder
Unfortunately worklog and was made with a camera not up and the images are not perfect.
I apologize in advance.
In these pictures we will see the first stages of processing of the plans of the desk.
Stay tuned.
Old 14th Mar 2017, 08:37   #6
Y.G Casemod
Minimodder
Material for cooling.
Part 1.
Stay tuned.
Old 15th Mar 2017, 09:00   #7
Y.G Casemod
Minimodder
The first test of the parts placement.
Old 16th Mar 2017, 22:31   #8
Y.G Casemod
Minimodder
Forming, cutting and drilling of the contour panel to the MB, and res pump panel with motherboard test positioning.
Below you can see the panel where it will be mounted res and pumps and the contour panel to the MB, and milling for LEDs made with pantograph for housing backlight.
Stay tuned.
Old 22nd Mar 2017, 17:04   #9
Y.G Casemod
Minimodder
Tanks flat for aesthetic loop on the front of the desk.
Old 25th Mar 2017, 21:46   #10
Y.G Casemod
Minimodder
Opening windows and holes for the fixing screws of the flat tanks on the front with Dremel.
For mounting screws I used Alu round and hexagon insert head.
Executed on the tanks leak test before mounting.
Old 31st Mar 2017, 10:40   #11
Y.G Casemod
Minimodder
Predisposition and preassembly test of flowmeters Aquacomputer High Flow.
Old 2nd Apr 2017, 12:34   #12
Y.G Casemod
Minimodder
New update
Construction of the cover for the bay 5.25 c.
This will need to close the back cover throughout the Aquaero apparatus for the management of the plant cooling which will include the Aquaero 6 XT most 6 complete their front panels Poweradjust.
Under the Aquaero it will also install a header with USB 3.0 ports
As we will see we will be established 2 ventoline to cool all the hardware in question.
Stay tuned.
Old 4th Apr 2017, 13:34   #13
Y.G Casemod
Minimodder
Realization stencils for airbrush.
Meanwhile came another parcel ......
Stay tuned.
Old 6th Apr 2017, 20:21   #14
Y.G Casemod
Minimodder
Old 9th Apr 2017, 08:54   #15
Y.G Casemod
Minimodder
Begin the painting phases.
In these pictures we see of the paint preparation by applying stencils for airbrush on the main floor of the desk.
Stay tuned.
Old 14th Apr 2017, 09:06   #16
Y.G Casemod
Minimodder
Before the paint, and then elbow grease ....
Stay tuned.
Old 18th Apr 2017, 21:44   #17
Y.G Casemod
Minimodder
Airbrush and colors.
Here's the first video of the airbrush the main floor.
The quality of the footage is not the best, and for that, i apologize in advance.XD
https://www.facebook.com/Y.Gabrielli...9397476753440/
Old 21st Apr 2017, 12:24   #18
Y.G Casemod
Minimodder
In these photos we see the various steps of completing the main floor.
From the removal of the stencils after the airbrushes, to the mounting of the rgb led with control unit.
Stay tuned.
Old 22nd Apr 2017, 09:00   #19
Y.G Casemod
Minimodder
Short video of the main floor finished with RGB lighting.
Here in demo mode.
You can change a variety of light games and LED colors through control unit and remote control.
This is the link at video.
https://www.facebook.com/Y.Gabrielli...4311969595324/
Old 22nd Apr 2017, 09:08   #20
Y.G Casemod
Minimodder
First mounting steps but it's just the tip of the iceberg .....
Stay tuned.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
