Reply
Thread Tools View Mode
Old 8th May 2017, 18:50   #21
ADmodz
69 Dude!!
ADmodz has yet to learn the way of the Dremel
Good evening.
A little watercool goodness arrived today
Big thanks to Jakob and his team for getting these made and delivered to me is supersonic time.
HEATKILLER IV PRO (Intel) acrylic
HEATKILLER IV RX480 acrylic
These will keep Sofia nice and cool.
ADmodz is offline   Reply With Quote
Old 8th May 2017, 21:05   #22
ADmodz
69 Dude!!
Well that's both watercool Heatkiller blocks installed.
just waiting for the case to come back from paint,and then we are ready for assembly
Old 10th May 2017, 20:34   #23
ADmodz
69 Dude!!
Hi all.
I'm just waiting for the Antec Cube case to come back from paint,the airbrushing was completed today.
They are applying the high gloss lacquer with a little metal flake in it tomorrow,so hoping to get it back by the end of the weekend.
So whilst waiting for that,I got some last little bits finished.
The Antec TrueQuiet 120 UFO fans have a semi transparent fan blade,which look good but not the finished look I was looking for.
I wanted a plain white halo ring,there's plenty of case lighting going on so wasn't needing the light glowing through the blades.
Also painted the Alphacool Eislicht casing,just to blend it into the inside case colour
Old 18th May 2017, 17:27   #24
ADmodz
69 Dude!!
Hi all.
The day finally arrived today...... Sofia's chassis was ready to collect from the paint shop.
ReBorn To Be Wild and Kustom sammy have done a fantastic job.totally blown away by the level of craftsmanship.
I'm letting you see a couple of pictures,but the rest of it will be revealed very soon.
ITS BUILD TIME.....
Colours:-
Chassis/Alphacool radiator casings:- custom candy white with a high gloss show lacquer with metal flake mixed in.
Case panels :- custom candy purple with a high gloss show lacquer with metal flake mixed in
All art work was airbrushed on by Kustom Sammy.
Enjoy....
Reply
Tags
#alphacool, #antec, #heatkiller, #msiuk, #teamgroup
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
