Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 14th Mar 2017, 05:21   #1
Cthippo
Can't mod my way out of a paper bag
Cthippo's Avatar
Cthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming SaiyanCthippo is a Super Spamming Saiyan
Online drive duplication software
I bought a Samsung 256 GB SSD to replace the overfilled 60 GB drive in my desktop, but I'm having trouble finding a drive cloning tool that will work. I downloaded the Samsung clone tool, which I used on my laptop and worked great, but for some reason it will not see the empty drive as being a Samsung SSD. This may be because it is a Lenovo replacement part and so maybe it identifies as Lenovo instead of Samsung.
I looked at the description for Clonezilla, but it cannot run from the disk being copied, so i would have to boot into a live CD or USB drive to run it, which i would rather not do if I can avoid it. Is there a free online drive cloning tool out there that you guys can recommend?
__________________
Notice: If we see you flaming we will assume you are on fire and take appropriate measures
- The Bit-Tech Fire Brigade.
Cthippo is offline   Reply With Quote
Old 14th Mar 2017, 07:06   #2
CrapBag
I Mod, Therefore I Own
CrapBag's Avatar
CrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming SaiyanCrapBag is a Super Spamming Saiyan
I always use EaseUs Todo Backup, never had a problem cloning SSD's with it.
CrapBag is online now   Reply With Quote
Old 14th Mar 2017, 13:53   #3
Cthippo
Cthippo's Avatar
That worked, though it was not without it's headaches. Have some rep!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
