Go Back   bit-tech.net Forums > Partner Forums > Asus UK
Reply
Thread Tools
Old 18th Mar 2017, 18:26   #1
bawjaws
Mod Master
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
ROG Strix Z270I Gaming - USB question
Hi ASus,
I've a quick question about the USB ports on the Strix Z270I Gaming ITX board. I see that the board has a USB type-C port on the rear I/O panel, plus three USB 3.0 type-A ports and four USB2.0 type-A. Am I correct in thinking that USB3.0 ports (both type-A and type-C) are 5GB/s, i.e. USB3.1 Gen 1 rather than USB3.1 Gen 2?
The only reason that I'm a bit confused is because your website refers to these four ports as USB3.0 but I've seen a couple of reviews (including this month's Custom PC magazine) refer to them as 2x USB3.1 Gen 1 plus one USB3.1 Gen 2 type-A and one USB3.1 Gen 2 type-C. Very confusing! I'd gratefully appreciate any light you may be able to shed on this - who knew USB terminology could be so confusing?
Cheers!
bawjaws is online now   Reply With Quote
Old 21st Mar 2017, 09:51   #2
Will_ASUSUK
Minimodder
Will_ASUSUK has yet to learn the way of the Dremel
Hi Bawjaws. I would probably go by the specs on the website and not by the ones listed in a review. If they say they are USB3.0 they will be rather than USB 3.1.
If you continue to have issues, please don't hesitate to contact us.
Kind Regards
ASUS UK Support team
Hotline: 01442-265548 9am - 5pm
Email: http://vip.asus.com/eservice/techserv.aspx
Website: http://www.asus.com/uk/support/
Will_ASUSUK is offline   Reply With Quote
Old 21st Mar 2017, 13:06   #3
bawjaws
Mod Master
Thanks for the reply, Will. It's a bit of a shame that the Z270I has gone backwards in terms of USB provision compared to the Z170I Pro Gaming, but I appreciate that it does offer a couple of features that the Z170I lacks.
Old 29th Mar 2017, 10:07   #4
Will_ASUSUK
Minimodder
No problem. There is a USB 3.1 header on the board to connect to your front panel should you want faster speeds. There is an m.2 socket with a double decker heatsink, you can get NVME speeds through that for storage.
Kind Regards
Bill @ ROG UK
Old 29th Mar 2017, 22:28   #5
bawjaws
Mod Master
Thanks, Bill. I've ended up going for a Z170i Pro Gaming as it's a better match for my requirements and budget, despite being a generation older.
Old 6th Apr 2017, 15:33   #6
Will_ASUSUK
Minimodder
Great board, had one myself Enjoy!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
