Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 20th Mar 2017, 08:28   #1
Kronos
Another grumpy old git.
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
Windows 10 settings transfer?
Unlike all other Windows operating systems of the past a lot more work is needed to set up Windows 10 to how I want it which means getting rid of Cortana and One Drive and turning off all the unnecessary stuff hidden away in the myriad of settings. Unfortunately I cannot remember all that I have done so each install it means googling to find the settings to alter.
I have a larger SSD arriving today and rather than clone I intend to do a fresh install as the larger size will mean I can remove a 3.5 HDD as it will not be needed.
My question is is it possible to transfer just my current settings which I can then incorporate in the fresh install? Or is it best just to do my usual Googling to get the info needed to have my PC set up yje way I want and not the way Microsoft wants?
__________________
Carbide 240/Asus Z170M plus/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/500Gb OCZ TR150 SSD/2 x 256Gb SSD/ 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GTX 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is offline   Reply With Quote
Old 20th Mar 2017, 09:39   #2
Broadwater06
Multimodder
Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.
I think you can't turn off Cortana in Windows 10 Anniversary update anyway. What's wrong with One Drive, it's free cloud storage except pay a bit more for more.
Broadwater06 is offline   Reply With Quote
Old 20th Mar 2017, 09:44   #3
Kronos
Kronos's Avatar
Couple of things.
Change turn off to disable where Cortana is concerned.
I did not say anything was wrong with One Drive but I do not want it forced upon me free or not.
__________________
Old 20th Mar 2017, 12:05   #4
Broadwater06
Multimodder
You're the Windows 10 Education man - that has no Cortana at all and save you the faff from disabling.
Old 20th Mar 2017, 12:08   #5
Kronos
Kronos's Avatar
I have Pro and am not a student.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
