Reply
Thread Tools View Mode
Old 22nd Mar 2017, 09:18   #1
ciobanulx
Modder / Watercooler
ciobanulx's Avatar
ciobanulx has yet to learn the way of the Dremel
Maul (modded Corsair 600C) by SimpleModz
Hi guys,
Welcome back to another one of my build logs. I'm pretty excited for this one
It will be based on Darth Maul and incorporate some interesting ideas with the Corsair 600C case!
I did a video covering the case, fully disassembling it as well as talking about the mods!
Check it out below:
SPECS:
Case - Corsair 600C
CPU - Intel Core i7 6700K or 7700K
MB - ASUS MAXIMUS VIII Extreme
RAM - 4 x 8GB Corsair Vengeance Red LED 2666MHz DDR4
GPUs - 2 x ASUS STRIX GTX 980Ti
SSD - 3 x 240GB Corsair Neutron XTi
HDD - 2 x Seagate TBC
PSU - Corsair RM850X
Custom cables and lighting - CableMod
Water cooling - Bitspower
Here are also some photos of the case to start off with
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
ciobanulx is offline   Reply With Quote
Old 4th Apr 2017, 14:06   #2
ciobanulx
ciobanulx's Avatar
Two of the 3 mods I'm currently working on
Maul is the one on the left in the Corsair 600C and the shell on the right is the Cooler Master MasterCase Maker 5t, this is my Tempest Mass Effect mod.
I already did some cuts in the 600C. Mainly the front panel section as well as the top. A bit more filing and tidying up of the cuts need to be done but it's coming along well so far
Stay tuned for more
Cheers,
Alex
Old 9th Apr 2017, 02:11   #3
ciobanulx
ciobanulx's Avatar
Hey guys,
I took apart the top and front panel further and did the cuts into the plastic part while I get the metal parts ready
The front panel 5.25" door cut out window
Top panel cut out window
Top panel metal part
Front panel metal parts
Cheers,
Alex
Old 14th Apr 2017, 14:49   #4
ciobanulx
ciobanulx's Avatar
Stay tune for Maul
Old 15th Apr 2017, 14:04   #5
ciobanulx
ciobanulx's Avatar
Here is what I'm currently working with! Imagine the horns and eyes lighting up once the build is finished! I'm also going with a battled and worn out weathered theme as well.
Everything was cut manually with a jig saw and a lot of filing. The cut-out at the top is a small window that will look into the top compartment.
Stay tuned for more!
Cheers,
Alex
Old 16th May 2017, 11:04   #6
ciobanulx
ciobanulx's Avatar
Hey guys,
Time to start focusing my attention back to this build log and get it all up to date! I've been pretty busy as always however the build is finished and I will unveil it over the next couple of days.
I just want to show you guys all the progress first and I still need to take final photos and film it.
I'll start with two massive 10TB Seagate IronWolf HDDs that are going in the build, a plethora of red Bitspower fittings and the simple weathering effects done to the case.
Hope you guys like it. Same as the front panel that I shared before, I wanted the build to look like it's been through a Star Wars space battle. The paint effects were done by dry brushing some simple acrylic paint, a very easy effect to achieve. You can also see an acrylic motherboard skirt cover panel.
Cheers,
Alex
Old 17th May 2017, 10:00   #7
ciobanulx
ciobanulx's Avatar
Hey guys,
The motherboard I'm using is the ASUS Maximus VIII Extreme with a full cover Bitspower Monoblock that I decided to remove the top cover from and have it exposed. The acrylic would probably do with some polishing however for this build, in terms of the other aesthetics, I think it should work well as is.
The two ASUS STRIX GTX 980Tis, still pretty good cards even today, with Bitspower full cover water blocks.
And the memory I'm using is the Corsair Vengeance red LED
They're pretty good how you can easily remove the tops to orientate the Corsair logo to better suit your build.
The tops could even be painted quite easily for further customisation.
And here's everything mounted inside, with tubes in so I can mark for the pass-through fittings on the front panel.
Cheers,
Alex
Old 18th May 2017, 16:00   #8
ciobanulx
ciobanulx's Avatar
Okay, here we go, pass-through fittings are mounted and the front acrylic cover panel is complete.
You can also see the motherboard skirt panel is ready as well, with reservoir mounts on.
Fans are going underneath the case and a 60mm thick radiator on top of them in the bottom of the case. I just wanted more room and the fans fit nicely underneath. Plus, they will give a nice glow underneath the case.
Cheers,
Alex
Old 20th May 2017, 02:13   #9
ciobanulx
ciobanulx's Avatar
Hi guys,
Here's most of the piping done!
One issue I had with this is that two of the pass through fittings were way too close to each other and I only had Bitspower C47 style fittings that were a bit too large. So I ended up hand filing them down.
This was the result:
Just shaved off a few mm and they fit perfectly with a bit of tubing between them.
They're the ones at the very bottom.
Mounted the RGB LED controller for the Corsair fans in the front as well. This will be accessible from the side even with the front panel on.
And here's a look at the cable management.
And now the inside.
The red chrome tubes, with the fittings in the middle is a reference to the dual lightsaber.
Cheers,
Alex
Old 21st May 2017, 01:42   #10
ciobanulx
ciobanulx's Avatar
Hey guys,
These were the final photos I took before getting all the panels on and finishing the build
As you can see, I went with black coolant and I also have a few red cold cathodes in there just for some more lightsaber references
Stay tuned for final pics!
Cheers,
Alex
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
