Old 23rd Mar 2017, 09:55   #1
goldstar0011
Mod Master
goldstar0011's Avatar
goldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyangoldstar0011 is a Super Spamming Saiyan
Posting issues
When I try to post I keep getting the below message but when I try again straight after it allows me
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
goldstar0011 is offline   Reply With Quote
Old 28th Mar 2017, 09:26   #2
goldstar0011
Mod Master
Is anyone else getting this?!
I just typed a long post and lost it because of this!
Old 28th Mar 2017, 09:32   #3
MadGinga
I *am* a Dremel
MadGinga's Avatar
MadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming SaiyanMadGinga is a Super Spamming Saiyan
I've seen this a number of times, only when trying to start a new thread (in the MP) - very annoying.
__________________
Gaming: i5-3570K | P8Z77-V | HyperX 4x4GB | 850 Evo 250GB | WD 1TB | EVGA GTX980ti SC | SB Xi-Fi | Define R5 | CM TX650M | Win 7 Ultimate | U2412M | Ducky Shine 5 RGB (Brown) | Logitech MX Master
Office: i3-3220 | H61M-K | 2x4GB | 120GB SSD | 120GB | HD7870 2GB | Elite 342 | CX600M | Win 7 | MS Desktop 600 | Logitech M185
Server: i5-3540 | P8H77-M | 2x4GB | 120GB SSD | 2TB, 2x3TB, 2x4TB | Define R5 | EVGA 500B | Win 10 | Logitech K400+ & M185
MadGinga is offline   Reply With Quote
Old 30th Mar 2017, 09:11   #4
goldstar0011
Mod Master
And again!
Gladly I saved copied the message I was posting
Old 31st Mar 2017, 09:14   #5
MLyons@BOXFX
Minimodder
MLyons@BOXFX's Avatar
MLyons@BOXFX has yet to learn the way of the Dremel
Originally Posted by goldstar0011 View Post
And again!
What browser are you using? Any plugins etc installed?
MLyons@BOXFX is offline   Reply With Quote
Old 19th Apr 2017, 08:55   #6
goldstar0011
Mod Master
IE11, no plugins, at work
but....
I don't recall having this issue at home but I don't post loads, let me try
It's still happening and making posting unpleasant
Old 19th Apr 2017, 17:01   #7
MLyons@BOXFX
Minimodder
but....
Is it happening at work and at home? I'll have a quick look and see if there's anything i can do. If not I'll speak to a colleague about it. If anyone else if having the issue post below.
Old 19th Apr 2017, 19:18   #8
goldstar0011
Mod Master
Test post
Old 19th Apr 2017, 19:19   #9
goldstar0011
Mod Master
ha....hummm...posting at home worked ok
Old 2nd May 2017, 11:53   #10
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Yup I'm out today on wifi and just got the same. Also using a MacBook with Safari, if that has anything to do with it.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
