Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 25th Mar 2017, 20:01   #1
Ant1981
Supermodder
Ant1981 has yet to learn the way of the Dremel
Windows Explorer has stopped working
Every so often, or almost every day, the computer will hang, then an error message will come up saying that windows explorer has stopped working. Nothing happens after this point and I need to press the reset button on the tower.
Almost every day I need to press the reset shortly after start up. Does anyone know what's going on? I've tried searching and there's been a few suggestions of what to look for or do but nothing is helping.
Thanks in advance.
Ant1981 is offline   Reply With Quote
Old 25th Mar 2017, 21:57   #2
loftie
Mod Master
loftie's Avatar
loftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyanloftie is a Super Spamming Saiyan
Tried sfc /scannow ?
__________________
Sent from my PC using a keyboard
loftie is offline   Reply With Quote
Old 25th Mar 2017, 22:18   #3
Ant1981
Supermodder
Yes, tried that.
Old 25th Mar 2017, 23:40   #4
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Which version of Windows?
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 26th Mar 2017, 16:49   #5
Ant1981
Supermodder
7 Ultimate 64 bit.
Old 26th Mar 2017, 18:23   #6
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
The event log should provide more details on what's causing explorer to crash, something like faulting module...
Corky42 is offline   Reply With Quote
Old 27th Mar 2017, 17:07   #7
Broadwater06
Multimodder
Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.Broadwater06 is the Cheesecake. Relix smiles down upon them.
It could be something in the context menu causing it to hang. I remember the Nvidia Control Panel used to cause this.
Give ShellMenuView a go and disable shell extensions. can't guarantee it'll work but give you another avenue.
Broadwater06 is offline   Reply With Quote
Old 17th Apr 2017, 09:24   #8
oliverpowell
What's a Dremel?
oliverpowell has yet to learn the way of the Dremel
I believe virus affects your system and that is why you are facing system-freezing issue. It is recommended to download an best antivirus software and scan your computer drive to troublehoot the Frizzing issue.
oliverpowell is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
