Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 26th Mar 2017, 20:14   #1
KarlAtlason
What's a Dremel?
KarlAtlason has yet to learn the way of the Dremel
Extracting files from ZIP archive.
How can I restore the backup which was created in Genie Manager? I lost a few files in the overall backup sequence. The software vendor knowledge base claims that the almost 2-gig backup files are really a zip file and should be able to unzip with any winzip type utility.
Problem and question: I get zip files, unzip them and all files are extracted fine, but an additional extension. For example document.doc gets extracted as document.doc.genc file.
I rename the file to document.doc and even though the file size, creation date is fine the file is unreadable. This applies to all files extracted this way. Anyone had any experience with this? Or what is a good zip un-corrupt utility out there?
KarlAtlason is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
