Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 29th Mar 2017, 12:09   #1
Otis1337
aka - Ripp3r
Otis1337's Avatar
Otis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming SaiyanOtis1337 is a Super Spamming Saiyan
Looking for a VPN.
So i use to use NordVPN, which is the most secure i know with the best policies but there software is very buggy and i use to get constant drop outs with inconsistent speeds.
Anyone else have any other recommendation. Must be able to use on the home router and phone.
Speed and connection stability is important.
__________________
Haswell killer - Long live x58
GTX 1080 FE::Xeon X5650 Hex @ 4Ghz::H110i GT::Asus P6T SE x58::Patriot Tri DDR3 12GB
CoolerMaster 850W RealPower::Phanteks Enthoo EVOLV::Sammy F3 1TB::OCZ SSD 2x120GB::Asus Xonar - HyperX Cloud
Otis1337 is offline   Reply With Quote
Old 29th Mar 2017, 12:22   #2
jinq-sea
The Double Insulates
Moderator
jinq-sea's Avatar
jinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyanjinq-sea is a Super Spamming Saiyan
PrivateInternetAccess. I think it'll run you to about 30/year.
__________________
Comrade Woody: "I dunno, whores are a bit like cornflakes, you always regret buying the cheap ones."
small(ish): i7-5960X / X99E-ITX/AC - Bitspower Block / 32Gb Ballistix / Titan X (P) / 512Gb Samsung 950 Pro NVMe / 250D
tiny: i7-4790K / Max VII Impact - EK Monoblock / 16Gb Ballistix / EVGA Titan X (M) HC / 256Gb SM951 NVMe / nCase M1
htpc/vr: i7-6700K / Z170i / 16Gb Ballistix / EVGA 1080 Founders Edition / 128Gb SM951 NVMe & Sandisk 960Gb SSD / RVZ01
jinq-sea is offline   Reply With Quote
Old 29th Mar 2017, 12:34   #3
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
it's more than that, I used to pay them about 7 quid a month when I was with PIA.
now I used CyberGhost VPN as I got a year sub from a humble bundle a while ago - it's less good than PIA, but it's cheaper for a year. When the sub is done i'm going back to PIA as it's the best.
PIA have a whole multitude of ways to connect, including being able to dial an IPSEC tunnel from your router, or ssl vpn, or they have a little app which you can use.
all the normal stuff like no logs, etc. etc. etc. etc.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 29th Mar 2017, 13:00   #4
Mister_Tad
Moderator
Modaretor
Moderator
Mister_Tad's Avatar
Mister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming SaiyanMister_Tad is a Super Spamming Saiyan
I'm paying $40/year for PIA. I think doing it monthly is considerably more expensive though.
__________________
Dell XPS15 9560 | i7-7700HQ | 32GB DDR4 | GTX1050 | 1TB NVMe | 97WHr | 4K IGZO Touch | Philips 328P 32" 4K | W10 Pro
HP Microserver G8 | Xeon E3-1265Lv2 | 16GB DDR3 12800E | 120GB 840 EVO | HP P222 512MB FBWC | 4x 4TB WD Red | W2016 Std
Mister_Tad is offline   Reply With Quote
Old 29th Mar 2017, 13:04   #5
Margo Baggins
Moderator
I didn't realise could do it annually, 100% going to do that when I sign back up again!
CyberGhost is crap, but got it with a $15 humble bundle for a whole year, so can't really complain.
__________________
My Imgur
keyboards.
Old 29th Mar 2017, 13:22   #6
Edwards
Hypermodder
Edwards's Avatar
Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.Edwards is definitely a rep cheat.
I've been rolling with airvpn for aronud 6 months and have been pretty happy with it.
__________________
i7 4930k - Asus Sabertooth x79 - 32GB - MSI GTX 970 - 240GB OCZ RevoDrive 3 - 512GB Samsung 840 Pro - 1TB Samsung F3 - 2TB Samsung F4 - 2TB Hitachi Deskstar- 3TB Seagate Barracuda XT - Corsair HX650 - LG IPS231P-BN x 2 - Corsair K70 - Logitech G502
Edwards is offline   Reply With Quote
Old 29th Mar 2017, 13:35   #7
jinq-sea
Moderator
jinq-sea's Avatar
That's the ticket. Annual. I thought $40 was alreet
__________________
Old 29th Mar 2017, 14:03   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Another vote for AirVPN here: zero logging, guaranteed, which PIA doesn't. I get shiny pennies if you use this link, or I don't get shiny pennies if you use this link instead.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 29th Mar 2017, 14:12   #9
Margo Baggins
Moderator
how do they guarantee it?
PIA do say it, https://helpdesk.privateinternetacce...of-your-users-
__________________
My Imgur
keyboards.
Old 29th Mar 2017, 14:22   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
Same way any of 'em do: by telling you they don't keep logs while hopefully not crossing their fingers behind their backs.
Looks like PIA might have changed that, then: that article says it was updated in January. I'm pretty sure it used to be listed on The One Privacy Site as logging, but it's now listed as not - so either they have changed it or I'm misremembering. They're still listed as problematical for a number of reasons, including being in the US (Fourteen Eyes member and 'Enemy of the Internet' status), while AirVPN is based in Italy so gets Fourteen Eyes status but not 'Enemy of the Internet'. They also meet the PrivacyTools criteria, which PIA doesn't.
EDIT: Although, at the moment, their homepage is borked and showing this image...
__________________
Old 29th Mar 2017, 19:59   #11
Margo Baggins
Moderator
I bet Italy's internet police are as bad as their postal system too - so that's a prime spot for the vpn service to be hosted
__________________
My Imgur
keyboards.
Old 29th Mar 2017, 22:50   #12
TheBlackSwordsMan
The world need more lemon cakes
TheBlackSwordsMan's Avatar
TheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming SaiyanTheBlackSwordsMan is a Super Spamming Saiyan
+1
Same here.
__________________
i5 2500K@4.3Ghz l Z77 Extreme6 l GTX 560 Ti l Corsair K70 l Crucial M500 l 8.5TB Storage l Seasonic X650 : Corsair K70 : Ikari Optical : Cambridge Soundworks FPS2000 4.1
TheBlackSwordsMan is offline   Reply With Quote
Old 30th Mar 2017, 12:37   #13
Kernel
Likes cheese
Kernel's Avatar
Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.Kernel is the Cheesecake. Relix smiles down upon them.
I signed up to PIA last night after reading this thread, I had been meaning to do it for a while tbh.
No issues during sign up and I have all my traffic running through the PIA VPN from my pfSense router over OpenVPN.
I also now have my phone set to connect to my home domain through my Sophos SSL VPN.
__________________
Main: Intel Core i7 6700 / ASRock Z170 Extreme4+ / CoolerMaster Seidon 120V / Corsair Vengeance LPX 16GB / Palit GTX1080 GameRocks / Antec TruePower New 650W / Crucial M4 64GB + 256GB / Fractal R3 / Dell U2713HM / Dell U2412
ESXi Server: HP Microserver G8 - Intel Xeon E3-1230 v2 / Crucial 8GB RAM / Crucial M4 256GB / 4 x HP 250GB | Xpenology NAS: HP Microserver G8 - Intel Celeron G1610T / 4GB RAM / 3TB WD Red / 2x Samsung F3 1TB Spinpoint
Kernel is offline   Reply With Quote
Old 30th Mar 2017, 12:37   #14
alfizzle
I *am* a Dremel
alfizzle's Avatar
alfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyanalfizzle is a Super Spamming Saiyan
I use PIA, no complaints with the service or software.
alfizzle is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
