Reply
Thread Tools View Mode
Old 1st Apr 2017, 20:25   #1
MooZ91
Multimodder
MooZ91's Avatar
MooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the Dremel
Rage - elite 130 casemod
This project will use a Elite 130 mini itx case, with some ideas on the way.
Some cuts for the case let me think about some ideas... checking the space for a sided-psu and new look for front.
MooZ91 is offline   Reply With Quote
Old 7th Apr 2017, 20:18   #2
MooZ91
Multimodder
MooZ91's Avatar
some misc, and setting the support for the psu.
Old 7th Apr 2017, 21:17   #3
MooZ91
Multimodder
MooZ91's Avatar
A cool project deserves a cool logo
As result of moving the PSU, the existing hole had to be cover in some way. i take advantage of the space to place a 80mm fan, helping to extract the hot air from the cpu cooler. Of course, not only that but a few details to match the theme.
found some tube fittings in the garbage... i guess it will has a second life.
Old 12th Apr 2017, 03:35   #4
MooZ91
Multimodder
MooZ91's Avatar
Updating the front... The best part, most of the pieces are recycled from previous works, only with a jigsaw gives the shape needed.
plus, other details
Old 16th Apr 2017, 22:12   #5
MooZ91
Multimodder
MooZ91's Avatar
working on top
Old 25th Apr 2017, 21:53   #6
MooZ91
Multimodder
MooZ91's Avatar
Paint it white!!... and other colors D:
Old 26th Apr 2017, 09:48   #7
kim
Multimodder
kim has yet to learn the way of the Dremel
impressive result...amazing hand and paint job, I enjoy and follow...
kim is offline   Reply With Quote
Old 5th May 2017, 15:45   #8
MooZ91
Multimodder
MooZ91's Avatar
Thanks for check
Found an old webcam... some transformation to super cannon D:
A few details, paint, airbrush and misc...
Old 10th May 2017, 21:36   #9
MooZ91
Multimodder
MooZ91's Avatar
More details...
The mixed color for Sleeving: White, gray and Black.
Testing the lights, first at bottom, but on top has better results.
finally, the damaged fan on front... the intake airflow will ensure the good work of the cpu cooler.
Old 11th May 2017, 09:11   #10
kim
Multimodder
great fan "damaging" but isn't it noisy when turned on with those cuts in the wings?
Old 15th May 2017, 05:12   #11
MooZ91
Multimodder
MooZ91's Avatar
Thought the same after finish, but the fan spin below 1500 RPM, barely feeling any noise. Any way, it is connected a fan controller to track the speed.
Few details more, an i/o shield to the mobo, and special thanks to AVEXIR for these awesome memory pack.
The "brain" of this unit, modeled in polymer clay, then airbrushed.
Misc...
Old Today, 05:55   #12
MooZ91
Multimodder
MooZ91's Avatar
Finally, here is the result!
Old Today, 08:16   #13
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
Great work - it looks fantastic.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170|32GB|256GB M.2|500GB SSDs|8TB NAS|980 Ti|3007WFP-HC|Parvum S2.0
David is online now   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
