Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 6th Apr 2017, 08:31   #1
ElThomsono
Mod Master
ElThomsono's Avatar
ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.ElThomsono is definitely a rep cheat.
IP address management software
Currently I co-manage a number of networks each with around 100 hosts in half as many subnets, spread across a series of VPNs to remote devices.
I've inherited a series of spreadsheets listing everything (perhaps 80% of everything, in reality) in a haphazard way, and I'd like to replace them with a bit of software that can ideally:
  • List subnets in use
  • List free subnets
  • Parse data that is put in to make sure it's correct
  • It'd be excellent if it could auto-discover things on an existing network
An example of an issue I'm trying to avoid is when we add subnets, they're usually /29, so if we add a /28 it consumes two blocks and sometimes this will be missed and a subnet will be assigned in the middle of a larger block that is in use.
I've had a peek at SolarWinds and it wasn't quite right, perhaps something more basic would be better?
This has to be something suitable for people who don't understand IP addressing to use, such as "I need n hosts, please give me some numbers to give to someone who understands them".
Is anyone doing anything similar? I've read the Wiki list of IP Address Management software but it would take an age to go through them.
__________________
If it's broken, I can fix it. But that's ******.
ElThomsono is online now   Reply With Quote
Old 7th Apr 2017, 15:05   #2
Votick
My CPU's hot but my core runs cold.
Votick's Avatar
Votick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming Saiyan
Only ever used IPAM from Solarwinds in a big enterprise environment.
I think its pretty good.
Votick is offline   Reply With Quote
Old 7th Apr 2017, 15:40   #3
ElThomsono
Mod Master
ElThomsono's Avatar
Thanks for replying; one of the things I would like it to do is parse subnets as they're imported and flag up conflicts, when I tried that in SolarWinds it silently dropped the duplicates
__________________
Old 7th Apr 2017, 15:45   #4
Votick
Votick's Avatar
Have you seen phpipam? Looks quite good might give it ago my self.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
