Reply
Thread Tools View Mode
Old 15th Apr 2017, 09:55   #1
InsolentGnome
Supermodder
InsolentGnome's Avatar
InsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming SaiyanInsolentGnome is a Super Spamming Saiyan
【MSI PRO MOD S5: Demonstration】Crevasse
Hey everyone, welcome to MSI's PRO MOD Season 5! My name is Dave Cathey, or InsolentGnome as a lot of folks know me. I hail from the US and I've been picked as a judge for this season. I know...crazy! Who in their right minds lets a gnome be a judge, let alone an insolent one, right? Part of the judging duties is to make a demonstration mod with the Arctic theme with the sponsor's hardware, which is some pretty nice kit, but let's start off with the theme...
This mod is named Crevasse. A crevasse is basically a crevice, but in a glacier. Crack in rock...crevice. Crack in ice...crevasse. It just sounds fancier, like a swan ice sculpture. The idea for the case is to appear to be a crevasse in an ice shelf that has opened up to reveal an inner cave. While it won't be as dramatic as it sounds, I think it should turn out pretty cool. Get it? Yeah, the puns will be out in force with this worklog.
For hardware, I'm starting off with the In Win 303 in white.
The motherboard is the MSI B350 Tomahawk Arctic.
And yes, you read that correctly, B350 so this baby is gonna have a new AMD Ryzen chip, the Ryzen 7 1700X to be specific.
Cooling for our Ryzen chip will be handled by the new MSI Core Frozr L tower cooler.
Populating the memory slots will be 16GB(4x4GB) of HyperX Predator DDR4 @3000MHz
Storage will be a HyperX 240GB Predator PCIe SSD in the M.2 slot.
Power is coming from a Be Quiet! Dark Power Pro 11 1000w PSU.
And case airflow will be handled by Be Quiet! Silent Wings 3 fans. Three 120mm and two 140mm.
I'm still waiting on some of the other hardware and will update as soon as it arrives.
The first thing we need to to with all this nice hardware is to set it up and get the board updated since that's been an issue with Ryzen. Break out the Open Benchtable.
This thing is pretty slick and lets you bench up a system pretty easily.
I know that the GPU coming is supposed to be a RX580, but all I had with an air cooler laying around was a GTX 760, but it will let me get started. Now to find a monitor...
Sponsored by:
__________________
Current Projects: The Gunslinger - CM Mastercase5, Crimson King - CM Mastercase5
Past Projects: Spark, F3, Shinai, Scout, Gigantea, Rehab, Twelve-80
For more randomness, check out my tweets or my face page or my website!
InsolentGnome is offline   Reply With Quote
Old 24th Apr 2017, 07:45   #2
InsolentGnome
Supermodder
The rest of the hardware came in this past week so let's see what we've got rounding out this build.
For a GPU, there's the brand new MSI RADEON RX 580 ARMOR 4G OC.
I've also got some nice peripherals that I'm gonna try and match to the build.
The MSI INTERCEPTOR DS4200 GAMING KEYBOARD.
The MSI CLUTCH GM40 GAMING MOUSE.
And the MSI DS502 GAMING HEADSET.
So with all the hardware in, it's time to get cracking on this project.
The first thing I did was strip most of the case down and tape it all up. I'm wanting to keep the finish. It's the right color and looks pretty durable. I left some of the interior so I could measure a few things.
Then I marked out a "safe" cutting area. This is where my design is going.
Now to mark out the cases namesake.
Wait. That doesn't look right...
Ah, much better. Did I mention that I'm rolling the case onto its back? The front becomes the top and the top becomes the front and the layout is reversed. It'll take some work to make it functional, But I'm liking the flip.
I took a Dremel and made some notches I could slip a jigsaw blade into.
And then surgery.
I didn't really go for precision with the jigsaw because I didn't want the blade to grab and bend anything. This InWin is thick aluminum, but I didn't really want to chance it. I'll go in with a grinder and take the rest of the material out. That is after I go get a better grinder for the job.
Sponsored by:
__________________
Old 29th Apr 2017, 15:30   #3
InsolentGnome
Supermodder
After some experimentation with different grinders, I figured out what works best and started cleaning up my cuts.
Sooo much metal dust!
Most of it was pretty easy, but the tips were a bit of a pain.
But totally worth it!
I did manage to scratch up the case a bit while doing this so painting is in it's future, but I'll cross that bridge when I get to it. There's gonna be lots of painting.
Next up was dealing with the GPU. I want to show it off, but the standard layout doesn't really do that. We're gonna need some metal.
Luckily I had some .063" or ~1.5mm 5052 left over from a previous project. Handy tip: label your scraps so you know what your grabbing, makes life easier. The best thing, this piece wound up being just the right width for what I was doing so all I had to do was mark out a cut and a bend.
Bending was done in a vise with some love from a hammer since that little tab wouldn't work too well in my brake.
Then I marked out my tab spacing from the original brackets.
Little work on the bandsaw.
Followed by a little filing.
And then marking out and drilling some holes...
And I've got a nice PCI bracket cover that uses the original mounting.
A little more work and it'll be ready to hold the GPU.
Sponsored by:
__________________
Old 8th May 2017, 05:46   #4
InsolentGnome
Supermodder
Pushing forward with the GPU mount, I decided to try something a little different from my norm for making GPU mounts and use the original I/O bracket as one of the mounting points. This let me just cut a slot in my bracket and not have to do any extra bending.
Everything turned out perfect...
Until I got to the CPU cooler. In order to clear the GPU it has to have a horizontal orientation with the motherboard.
Which wouldn't be a problem except that AM4 bracket for the Core Frozr L doesn't work that way.
After marking out some changes, I did a little grinding to make everything fit.
And that worked perfect...except that now it clips the top of the RAM in the first slot. Not really hard contact, but touching so that needs to be addressed.
Clipping off the bottom fins with a Dremel solved that problem.
So now that it fits, I need to go in and get the logo right side up since the cooler is asymmetrical and I can't just flip it over. Luckily, MSI had me covered on that front. The top of the cooler was easy to take apart and flip.
But while I'm here, I'm thinking an arctic theme for the MSI logo, so let's check out that badge. It's painted clear plastic over a LED sheet. With some thinner, the paint came off so I don't think it'll be hard to use a bit of paint and vinyl to switch the colors up to blue and white to match the build.
Sponsored by:
__________________
Old 15th May 2017, 04:44   #5
InsolentGnome
Supermodder
So...painting. OMG so much painting and I haven't even touched the case yet. First up, we gotta take some stuff apart.
And clean all the adhesive off.
Priming...
I decided on white and a couple of blues for the color scheme. To help the blues really pop, everything got a coat of white though. I decided to airbrush the pieces that were going to be blue, that way I didn't have to wait 48 hours for rattle can paint to cure. The water based airbrush paint is ready to go as soon as it dries.
I did rattle can the fan frames, and that turned out to be a mistake as the rubber edges didn't want to cure. And cleaning off the edging and getting a nice finish was a pain so I decided to do some alterations to the fans. Since the mounts will keep the fans spaced away from anything that might interfere with the blades, I just sanded off the lip that held the edging.
Then I went back and hit them with the airbrush, once again for the quick turn around.
With the white sorted out, next up was some blue.
And to give things a frosty look, I went back and airbrushed some frost onto everything.
Then I got to put it all back together.
The CPU cooler. I still need to cut a vinyl decal to replace the logo I took off.
The RX580.
I'm really happy with how the RAM turned out.
And the fans.
Still working on the PSU, that thing is a pain to take apart. Supposed to get some material in this week that will let me start working on the base for the case so I can get it painted too!
Sponsored by:
__________________
Old 15th May 2017, 07:25   #6
ADmodz
69 Dude!!
ADmodz has yet to learn the way of the Dremel
Great work,subbed
ADmodz is offline   Reply With Quote
Old 15th May 2017, 16:46   #7
InsolentGnome
Supermodder
Originally Posted by ADmodz View Post
Great work,subbed
Thanks!
__________________
Old Yesterday, 06:53   #8
InsolentGnome
Supermodder
While taking apart the PSU, it shows that there is a lot of thought put into making it quiet, unfortunately that makes taking it apart and painting it a bit difficult.
I had to get creative because you can't separate the board from the casing without un-soldering it. Once everything was unpainted, it was time to sleeve up the 24-pin. I went with MDPC sleeving because of the color selection.
Super nice stuff, and it looks and works great, just reminds me how much I dislike how stiff it makes the cables though. :/ That's always a factor if you've got some tight spots or short runs. But anyways, once the 24 was sleeved, I could put the PSU back together. I painted it to match the rest of the components, even though you won't see some of the details.
With most of the painting out of the way, I could start on cleaning up the interior of the 303. I want to cover up a lot of the mounting holes since I won't be using them. Decided to use a translucent blue acrylic. I really like this color and it lights up pretty well with LEDs.
This just barely slipped past the board but will look super clean.
And with a bit of filing this piece will finish the look. Some LED strips behind it should give it a nice glow.
Sponsored by:
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
