Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 17th Apr 2017, 11:03   #1
David13
Minimodder
David13 has yet to learn the way of the Dremel
Retail Edition
Hi,
Many moons ago I bought the Windows 7 Retail edition. If I am correct I can have it installed on one PC at a time but the license is valid forever.
A hypothetical question, as it is upgraded to Windows 10 if I were ever to build a new PC can I uninstall the OS and then install the original Windows 7 and purchase a upgrade to windows 10?
David13 is offline   Reply With Quote
Old 17th Apr 2017, 11:15   #2
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
if you build a new pc - just install windows 10 on it and reactivate it. If you've done an upgrade you have a license attached to your account and you can change the hardware on that, Ive done it a few times.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 18th Apr 2017, 13:55   #3
Behemoth
Timelord in training
Behemoth's Avatar
Behemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming Saiyan
As stated above.
Just install Windows 10 from scratch with the code you installed 7 with originally and it will activate with no head aches at all
__________________
|AMD FX 6300 Black Edition|16 Gig of Ram|GTX 660|Corsair Carbide Air 240|
|AMD A8 3870|8 Gig of RAM|Radeon 5450|Some Unknown MATX Case|
|MacBook Pro 7.1|Intel Core 2 Duo 2.4 GHz|6 Gig of RAM|
|Dell Latitude E6320|Intel Core i5 2520m 2.5 GHz|8 Gig of RAM|
Behemoth is offline   Reply With Quote
Old 18th Apr 2017, 22:59   #4
Dr. Coin
Supermodder
Dr. Coin's Avatar
Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.Dr. Coin is the Cheesecake. Relix smiles down upon them.
Originally Posted by Behemoth View Post
As stated above.
I got to try that when I get home, I replace motherboard and lost my activation, did want to go back to 7 and didn't want to pay for 10. Been running with the activation notification in the bottom left corner for a couple months now.
__________________
Wait, Iíve got an idea, and it doesnít require high explosives.
-Sam & Max Hit the Road
Dr. Coin is offline   Reply With Quote
Old 20th Apr 2017, 06:15   #5
Margo Baggins
Moderator
this is the page you need:
https://support.microsoft.com/en-gb/...-10-activation
Activating Windows 10 after a hardware configuration change
If you made a significant hardware change to your device (such as replacing the motherboard) Windows 10 might no longer be activated. If you're running Windows 10 (version 1607 or later) and added your Microsoft account and linked it to the digital license on your device, you can use the Activation troubleshooter to reactivate Windows. For more info, see Using the Activation troubleshooter.
__________________
My Imgur
keyboards.
Old 22nd Apr 2017, 07:23   #6
Dr. Coin
Supermodder
Dr. Coin's Avatar
The advise on the Microsoft's website didn't help, as I do not have a Microsoft account and thus have not linked the digital license to my account.
However, as Behemoth pointed out, using my retail Windows 7 license key allowed me to activate windows 10 on my new system. I assuming this only work since I perviously migrated the license from 7 to 10.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
