Reply
Thread Tools View Mode
Old 20th Apr 2017, 13:40   #1
C4B12
Minimalistic PC's
C4B12's Avatar
C4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on youC4B12 - may the hammer of Bindi be bestowed on you
SAIL by C4B12 | 17-05-16 - Fan-grills and sidepanels cut out
Hello!
I have started a new project on the side of my other build, CURV3D. The idea to this build started when I was planning another future build. This other build I want to make in the future are also a scratchbuild and a bit complicated, so I wanted to get more experience on working with aluminium, so whats better then building a simpler case?
I got some hardware cheap secondhand, a Intel i3 4150 and a EVGA GTX 750ti which will be installed on a MSI Z87i and then be powered by a 150W Pico-PSU. The CPU will hopefully be changed out to something a little bit more powerful.
The case will be made out of 2mm aluminium with simple handtools (jigsaw, drill, dremel and handfiles). I did not want to make a regular cube-looking case so I will go for a angled roof and graphics card.
The hardware that will go into this build is this:
Mobo: MSI Z87i
CPU: Intel i3 4150
GPU: EVGA GeForce GTX 750Ti SC
RAM: Corsair Vengeance LP 2x4GB DDR3
SSD: Corsair Force LX 240GB
PSU: Streacom Nano-PSU 150W
Cooler: Noctua NHL9i
Rad: Magicool 92mm radiator
Pump/res: Alphacool DC-LT combo
GPU-block: EKWB FC750 block
Update 1 - Frontpanel and base
Update 2 - Backplate and mounting graphics card
Update 3 - Layout, pump-mount and sleeving
Update 4 - New CPU
Update 5 - More sleeving, SSD and IO-cover
Update 6 - Sintech PCIe riser
Update 7 - Fan-grills and sidepanels cut out
I hope you will stay and see the progress.
Best regards,
Johan Nyman
__________________
Scratch builds | The Red One | Cold Winter | CURV3D | C.ACE | SAIL |
Casemods | BarPC | F4DE | Spec-Edge |
Check out Minimalistic PC for news about modding and different projects!
C4B12 is offline   Reply With Quote
Old 20th Apr 2017, 13:41   #2
C4B12
Minimalistic PC's
C4B12's Avatar
Update 1
So what I started doing was to cut out the bottom plate and backplate.
I am using the cubes that Parvum sells to put everything together, nice ones actually.
I measured out the holes for the motherboard standoffs and drilled them out and used a M3 tap to make some threads.
Aaaaand done!
This will be the layout of the case and hardware. What do you think?
Best regards,
Johan Nyman
__________________
Old 20th Apr 2017, 13:42   #3
C4B12
Minimalistic PC's
C4B12's Avatar
Update 2
I decided on going for a bare metal - green theme. So the aluminium will be roughly polished and I will sleeve the few cables there is white-grey-green.
Next thing on the list was to cut out the I/O-plate. I did a rough cut with the jigsaw and then uses handfiles to get some nice edges. I always have a lot of tools on the table while working, embracing the chaos.
Then I used my Dremel to cut of the GPU-plate so it would be singleslot. I also bent back the little bend on the edge so the entire plate is flat....
...so I could us it to measure out the holes for the DVI, HDMI and DP.
To get those holes out I started by drilling holes in the edges and then used my Dremel to cut out some lines.
Woho! Just needs some finishing touches.
This is why I bent the plate so it is flat, so I could be able to fasten it to the backplate.
Looks like this from the other side.
What do you think so far?
Best regards,
Johan Nyman
__________________
Old 20th Apr 2017, 13:42   #4
C4B12
Minimalistic PC's
C4B12's Avatar
Update 3
Drilled holes to mount the frontpanel to the bottom.
This is how the frontpanel will look like, whats left to do is to cut out the hole for the fan and the switches.
This is how the layout on the inside will be, I changed the position of the radiator and reservoir to get a tighter loop.
This pump/res fits pretty good like this with the 92mm radiator.
What is this then?
Bent plate...?
A quick and simple pumpmount, it will be screwed down to the bottom of the case with foam between.
This is a small 4-port fan-controller which will control the three fans and the pump.
Some sleeving done too!
Next thing on the list to do is to solder and sleeve cables for the switches, pump and the power for the SSD, cut out the hole for the 92mm fan in the front and then start to make the sidepanels.
See you next time!
__________________
Old 20th Apr 2017, 22:43   #5
kim
Multimodder
kim has yet to learn the way of the Dremel
that's lovely...sometimes it doesn't require a lot of stuff to make it out....just great, i'm following
kim is offline   Reply With Quote
Old 21st Apr 2017, 04:32   #6
eucalyptus
I am 19 and Swedish!
eucalyptus's Avatar
eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.eucalyptus is definitely a rep cheat.
Okay Johan, you got my attention!
I don't like what I see. I love it!!!
Awesome choice of reservoir and great work with the custom case, and the sleeving is so bright. White, Grey and green just looks astonishing together, wow!
Wonderful name for the build too I wait patintetly to see more
Good luck and hope to meet you soon again at DH
__________________
Project Three Leaves / Build log / Galleries - Daylight / Night Vision / My setup
V8 Ocean / Build log
Follow- or send me a message on Facebook /Sebastian Edemalm
eucalyptus is offline   Reply With Quote
Old 21st Apr 2017, 05:41   #7
MeMo
It is what it is
MeMo's Avatar
MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.MeMo is the Cheesecake. Relix smiles down upon them.
Nice!!!
__________________
Ahhhh lets take it to the house "NUFF SAID"
MeMo is online now   Reply With Quote
Old 21st Apr 2017, 10:51   #8
C4B12
Minimalistic PC's
C4B12's Avatar
Hi Kim! Thanks, I enjoy building stuff with simpler tools, it does not have to be that difficult.
Thanks Sebastian!
I will see you at DHS for sure, are you going to bring your V8 for the modding contest? I will finish this build and bring it with me then.
Originally Posted by MeMo View Post
Nice!!!
Thanks MeMo!
__________________
Old 21st Apr 2017, 17:58   #9
SiberianGhost
Minimodder
SiberianGhost has yet to learn the way of the Dremel
Sweet hardware disposition, I like how everything is well measured. Subbed!
SiberianGhost is offline   Reply With Quote
Old 21st Apr 2017, 20:25   #10
C4B12
Minimalistic PC's
C4B12's Avatar
Thanks! I could have made it even smaller, but I wanted to try to find some balance between making it as small as possible and also making it look good.
__________________
Old 26th Apr 2017, 23:31   #11
C4B12
Minimalistic PC's
C4B12's Avatar
Yay I found a cheap i3 4150 on eBay yesterday, 50$ + shipping. Thats gonna be a bit better compared to the G3258 as the i3 has HT.
__________________
Old 26th Apr 2017, 23:33   #12
MeMo
It is what it is
MeMo's Avatar
Awesome!! Sounds like a Weiner!
__________________
Old 26th Apr 2017, 23:46   #13
C4B12
Minimalistic PC's
C4B12's Avatar
Yeah I think it will fit this build a lot better, another nice part would be a 1050ti, but well see.
__________________
Old 27th Apr 2017, 14:13   #14
C4B12
Minimalistic PC's
C4B12's Avatar
Ohoi!
I got some time over to work a little bit more on the build, getting some more work done on the sleeving and cablemanagement as well as mounting the SSD and making a IO-cover.
Lets start with the SSD mount, I am using a 2.5" Corsair LE200, mounted it with screws from the bottom.
Most of the 2.5" drives only use 5V and GND from the SATA-power, so instead of soldering another cable to the Pico-PSU I will power the SSD from the internal USB-port.
I wanted to cover up the IO-part of the motherboard, so I cut out a small aluminium piece which I bent.
I marked out where to cut out holes for different components near the IO-port.
It ended up looking like this, later on I will paint this and other parts matt black. The case will be polished and I will add different matt black details.
Im using P-clips to hold down the cables as I want to plan out and get a cablemanagement as good as possible.
Next up is the sidepanels and the hole for the fan, Ill be back!
With kind regards,
Johan Nyman
__________________
Old 4th May 2017, 11:02   #15
C4B12
Minimalistic PC's
C4B12's Avatar
Sintech PCIe Riser
Hello!
Today I received a small package in the mail, the last part for the build.
What can this be?
Yay! A 5cm PCIe riser-cable from Sintech. Took a while to find one that would fit the build.
LIKE A GLOVE
Im really happy with this little part, perfect size.
Best regards,
Johan Nyman
__________________
Old 4th May 2017, 20:40   #16
kim
Multimodder
it's as pretty as was your CURV3D...I really love your minimalistic builds, btw, what do you plan for the color of the case? unless you are aiming some nice brushed alu...or else?
Old 4th May 2017, 22:18   #17
C4B12
Minimalistic PC's
C4B12's Avatar
Thanks for the kind words kim!
Im planning on going for brushed or polished aluminiun with matt black details.
__________________
Old 10th May 2017, 16:35   #18
LePhuronn
Multimodder
LePhuronn's Avatar
LePhuronn has yet to learn the way of the Dremel
Sick work, love it! It's a pleasure to be nominated alongside this!
__________________
Project: ASTERIA II: Rearmoured
In Win 901, case mod, watercooled | Modding update nominee April 2017
LePhuronn is offline   Reply With Quote
Old 13th May 2017, 02:02   #19
C4B12
Minimalistic PC's
C4B12's Avatar
Thank you! Good job yourself!
__________________
Old 16th May 2017, 21:17   #20
C4B12
Minimalistic PC's
C4B12's Avatar
MOAR ALUMINIUM!
Oi!
Time for another update, Dreamhack Summer is getting closer and I get more work and personal stuff to do, so I am a bit stressed, if it gets to much Ill just skip the modding contest, modding projects should not be stressed I think. Enough with that, lets see some photos.
I re-stocked some aluminium today, 2000x1000x2mm.
I also changed some of the design, instead of cutting out the holes directly in the panels, I wanted to make fan-grills, that will be painted matt-black together with some other small details. As I have a bit limited time I got help from a friend, Laine, a extremely talented modder. He helped out with the fan-grills.
This is how they ended up, the one with stripes will be on the outside of the case.
The one with the sails will be here, on the NHL9i.
I started to cut out the hole in the frontpanel.
Filed down the shape and edges.
This is how it ended up, the other fangrill with stripes will be on the sidepanel.
Next thing to do is to start cutting out the both sidepanels.
This is the right sidepanel/bottom which I bent in my small sheet bender.
Two cubes were installed to the bottom of the case which will be screwed together with the right sidepanel/bottom piece to make the upper case look like its "floating".
Onto the left sidepanel/top piece, bent in a angle.
This is how it ended up, the case is starting to take some shape now.
Thats it for tonight. Next thing to do is to file down the sidepanels so everything fits better and start drilling holes to be able to mount everything together. A window will be cut out in the top to so its possible to see some watercooling stuff and hardware.
The hole for the 92mm fan on the side needs to be cut out as well. The fangrills, IO-cover and pump-mount will be painted mattblack too. Case will be polished up.
Hopefully I will be back in a few days with another update.
Best regards,
Johan Nyman
__________________
Reply
Tags
mini-itx, minimalistic pc, modding, sail, scratchbuild
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
