Go Back   bit-tech.net Forums > Modding > Watercooling: in association with Aquatuning
Reply
Thread Tools
Old 23rd Apr 2017, 18:52   #1
camelsnowman
What's a Dremel?
camelsnowman has yet to learn the way of the Dremel
Upgrading low flow pumps; concerned about flow of radiator
Hi all,
I have an old liquid cooling setup with a leaky reservoir/pump assembly. I'm considering replacing the reservoir/pump with a D5 pump, however, I'm wondering if my radiator will put too much strain on a D5.
The system in question is a Koolance EXT-A01. (It's super old and has been running pretty well for the last 13+ years). The system has a sealed reservoir with 2 Koolance R-PMP01 pumps. If I understand correctly, one pump pushes coolant out of the res into the rad, and the other pulls coolant back into the res from the water blocks.
I'm wondering if the radiator is designed for a relatively low flow rate, and if pairing it with a higher flow pump would put too much resistance/strain on a new pump.
I haven't been able to find specs from manufacturers for the components in my system, but here are some reasons I suspect the system has a low flow rate:
1. The system came with tubing with a 6mm ID and uses 6mm tubing to connect the pumps to the rad;
2. The rad has barbs for 6mm ID tubing (barbs cannot be removed from rad);
3. The CPU block (EK-Supremacy Clean CSQ) contains about 1/4 - 1/3 air (visually observed) (this is after months of running and trying to bleed it out by tipping); I'm thinking the current pumps don't have a high enough flow rate to push all the air out of this block;
4. This review: https://www.pcper.com/reviews/Cases-...nts-and-Design states the flow rate at 2L/min (the review is for an Exos 2, but the reservoir/pump configuration looks the same).
I have 2 water blocks:
- CPU water block: EK-Supremacy Clean CSQ
- GPU water block: EK-FC460 GTX - Acetal + Nickel
Ideally I'd like to add more quick disconnects so the motherboard and graphics card can be easily removed. I'm not sure how much they affect flow rate/pressure.
I like the idea of dual pumps, but my wallet does not Sooo, if I can get away with a single pump, I'd like to go that route.
I was wondering if anyone has thoughts/ideas on how a D5 might work in this scenario and I'd also like to hear other thoughts and ideas on this scenario.
Thanks for your time!
Additional information about my setup (not sure if it's relevant):
- The Koolance unit (rad, reservoir, pumps) internally uses 6mm ID tubing and have what appear to be 6mm ID quick disconnects on the back (to connect to the computer);
- I'm using 10/13mm tubing after those quick disconnects
- There are 2 G1/4 quick disconnects with 10mm ID compression fittings going into my case
- All the blocks use G1/4 10/13mm compression fittings
Last edited by camelsnowman; 23rd Apr 2017 at 19:44. Reason: Added source (review) for flow rate.
camelsnowman is offline   Reply With Quote
Old 23rd Apr 2017, 21:33   #2
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
http://www.ebay.co.uk/itm/SC600-DC-1...item2a5a992358
I bought one of those last November and it has worked faithfully ever since. I took it apart before using it to inspect its construction and noticed it had both a ceramic bearing and shaft.
Unless you are hell bent on it there is absolutely no reason to spend a fortune on pumps IMO.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 23rd Apr 2017, 22:33   #3
camelsnowman
What's a Dremel?
Thanks for the tip, Vault-Tec! I hadn't thought to check out other pumps on ebay.
Old 24th Apr 2017, 11:56   #4
Vault-Tec
Vault-Tec's Avatar
If you put SC600 pump into Youtube you will find several videos of people using it
__________________
MUWC Winner ROTT
Reply
Tags
pump flow rate radiator
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
