Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 7th May 2017, 16:33   #1
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Batman VR on DK2?
I've scoured the internet trying to get an answer, no luck. It says it needs a controller, but you can use a Xbone controller. Yet nowhere on Google or Youtube can I find any evidence of this.
Has any one tried it? funds are tight so I don't want to tie up 15 and then have to put in for a refund.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 7th May 2017, 16:40   #2
VipersGratitude
Mod Master
VipersGratitude's Avatar
VipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming SaiyanVipersGratitude is a Super Spamming Saiyan
These came up on my first search:
http://support.wbgames.com/link/port...tman-Arkham-VR
http://www.independent.co.uk/life-st...-a7346461.html
"First, to fully enjoy the game we highly recommend investing in PlayStation Move controllers; without them, it’s just not the same immersive experience."
The answer seems to be that you don't need oculus touch-type controllers, but they are highly recommended.
__________________
"Power without love is reckless and abusive; Love without power is anemic and sentimental"
~- Dr. Martin Luther King
VipersGratitude is offline   Reply With Quote
Old 7th May 2017, 16:48   #3
Vault-Tec
Vault-Tec's Avatar
Yeah it's not concise enough though that's the problem. As you say, you can use a controller but it's not the same etc.
Would just like a definite answer yay or nay. Ah well, will hold off for now.
__________________
MUWC Winner ROTT
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
