Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 11th May 2017, 20:56   #1
numanoid
Mod Master
numanoid's Avatar
numanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for presidentnumanoid should be considered for president
Is Battlefield 1 available on PC DVD
Hi guys where can i get a copy of battlefield 1 on dvd for the pc
Cheers guys
numanoid is offline   Reply With Quote
Old 11th May 2017, 22:05   #2
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
Looking at my Battlefield 4 folder, it measures at 68GB (with all of the expansions), which is a tad more than the capacity of a DVD. So even if you could get one you would have to download it anyway.
If you want a physical thing, you could pick up a collectors edition somewhere. Still no disc though.
theshadow2001 is offline   Reply With Quote
Old 11th May 2017, 22:25   #3
fix-the-spade
Mod Master
fix-the-spade's Avatar
fix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyanfix-the-spade is a Super Spamming Saiyan
Apparently not. All the 'physical' editions contain a download code in a box whilst all the DVDs of it I've found are ROMs.
__________________
CMDR Fix-the-spade
fix-the-spade is offline   Reply With Quote
Old 12th May 2017, 14:55   #4
numanoid
Mod Master
numanoid's Avatar
Cheers guys, i appreciate all the help
Thank you
Old 12th May 2017, 15:36   #5
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Even if it did you don't want the pain of installing it tbh. I've got GTAV on DVDs ( seven...) and installing it is a nightmare. It didn't give me a code for downloading either. Oh, and once you've spent the most part of a day installing it it then goes online and spends an hour or so downloading more lmao.
I always use key sites now. CDKeys has been my fave lately. Little bit more expensive than G2A, but I have had no issues with them and their customer service has been fantastic.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
