Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 11th May 2017, 20:59   #1
Invictus.
Hypermodder
Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.Invictus. is definitely a rep cheat.
Updating Windows 10 using a USB Drive?
Hi there,
Sorry if this is a "stupid" question.. In short at work we are having some issues upgrading to the latest builds of windows 10.. Using the upgrade assistant we generally get an error code 0x80190001 of which looking online just says use the media creation tool instead.
When trying to use the media creation tool with either "update this PC" or the "create a USB / download ISO" option it reports an error code of "0x80200013 - 0x90017" Of which I can only find relates to a firewall or proxy issue..
The oddest thing was that the tools used worked perfectly fine yesterday.. Now onto the original question really.. on my home PC I have the Content creators update etc, If I was to create the ISO I can use this to update the systems at work using all of their licences right? As the ISO doesn't get tied to any licences based on my understanding?
Invictus. is offline   Reply With Quote
Old 11th May 2017, 21:31   #2
Behemoth
Timelord in training
Behemoth's Avatar
Behemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming SaiyanBehemoth is a Super Spamming Saiyan
Originally Posted by Invictus. View Post
Hi there,
Your licence gets bound once Windows has activated after the installation or there is a licence that qualifies which is hard coded into the BIOS of the machine your installing to.
__________________
|AMD FX 6300 Black Edition|16 Gig of Ram|GTX 660|Corsair Carbide Air 240|
|AMD A8 3870|8 Gig of RAM|Radeon 5450|Some Unknown MATX Case|
|MacBook Pro 7.1|Intel Core 2 Duo 2.4 GHz|6 Gig of RAM|
|Dell Latitude E6320|Intel Core i5 2520m 2.5 GHz|8 Gig of RAM|
Behemoth is offline   Reply With Quote
Old 11th May 2017, 21:33   #3
Invictus.
Hypermodder
Thanks for the reply. I thought that was the case just wanted to be sure before going ahead and attempting it that to start it actually is possible and secondly that it won't really affect anything other than applying the updates
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
