Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 12th May 2017, 10:33   #1
hairyknacker
Multimodder
hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.hairyknacker is definitely a rep cheat.
Clone issue- cant remove a folder
I am needing to clone a HDD to a new SSD but the HDD has a large WindowsAPP folder with blue arrows top right corner- 221GB- that I cannot remove, delete or anything with it. Permissions look ok as far as I can see. The drive is in an external caddy and is from a different windows machine- I am cloning it which contains my Steam and Origin folders with a couple of other games that I cant reinstall due to lost disks etc so I need to clone it rather than copy the contents
Is there a way I can clone the other stuff without that folder as it is too large for the new SSD- I need to clone rather than copy as I need to keep the Windows links to the software on the drive
Thanks
hairyknacker is offline   Reply With Quote
Old 14th May 2017, 12:27   #2
hairyknacker
Multimodder
Sorted by using Ubuntu live and deleted folder
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
