Hardware AMD Ryzen 5 1400 Review
Discussion in 'Article Discussion' started by Dogbert666, 12 May 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    Sorry but that question doesn't really add up, it should be very apparent that it isn't a cheap 7700k (it can't compete on clocks and doesn't have the advantage of more cores like other Ryzen offerings), the more apt question would be if it is a better option than the bottom of the Intel Quadcore barrel, the i5-7400.
  3. Dogbert666
    17 Jan 2010
    I think Ant (who wrote the description) was more referring to the fact that on paper the two are similar: 4C/8T CPUs that are unlocked. But the implication of the question is more, as you point out, that they're not. Like, is it really what it might first appear to be?
  4. gasolin
    gasolin What's a Dremel?
    20 Jul 2017
    Why does it say less than 500 in cinebench R15 multithread with an i5 7600k at 5.1ghz ?[​IMG]
  5. RedFlames
    23 Apr 2009
    Because the graphs are broken... the labels and bars doesn't even remotely line up for any of the graphs...
    Assuming the red bars are the 1400 results then the 7600k @ 5.1 scored 814 in cb R15
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Yeah, those graphs are all sorts of screwed up.
  7. gasolin
    20 Jul 2017
    Theres still something wrong
    If 446 is the score for a i5 7600k theres something wrong, i get above 500 with my i5 7400 [​IMG]
  8. RedFlames
    23 Apr 2009
    That's because... The. Graph. Is. Broken.
    The 7600k scores 814 at 5.1 and 666 at stock... [the results above and and below the lower red bar which is the result for a stock speed 1400]
  9. gasolin
    20 Jul 2017
    what is the score of the r 5 1400 at 3.9ghz? 816?
  10. RedFlames
    23 Apr 2009
    After feeding the labels and results into Excel, this is what i got...
    The 1400 score 867 at 4GHz and 702 at stock:
  11. gasolin
    20 Jul 2017
    Screenshot not working, so a rysen 5 1400 is faster at 3.9ghz than a i5 7600k at 5.1ghz, i guess the i5 is faster for gaming?
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you care about performance, price and power consumption then:
    The i5 7600k is the best gaming cpu by a long shot.
    The R7 1700 is the best non gaming cpu by a long shot.
    (assuming both of them are oc'd).
    If you care about performance only:
    The i9 7900x is the best cpu by a long shot (for a couple more days).
  13. gasolin
    20 Jul 2017
    I don't have a money tree in my backyard
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
    Wait for the R3 Ryzen then if you can, most of the performance of an R5 1400 but for the price of a locked down i3.
  15. gasolin
    20 Jul 2017
    I don't think it would be worth it i5 to ryzen 3, i5 to ryzen 5 that would be okay
  16. Anfield
    Anfield Multimodder
    15 Jan 2010
    Sorry, misunderstood your comment about not having a money tree as you looking for a budget cpu.
    Yeah, definitely wouldn't be worth it.
Tags: Add Tags
