Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 15th May 2017, 11:43   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Purported leak outs Intel's Skylake-X Core i9 family plans
Positioned above the Core i7, leak claims.
https://www.bit-tech.net/news/hardwa...ke-x-core-i9/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 15th May 2017, 12:38   #2
Wakka
Yo, eat this, ya?
Wakka's Avatar
Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.Wakka is definitely a rep cheat.
I haven't been so confused in a CPU line-up in years.
Honestly, the idea of a 4c/4t i7 is bonkers (considering current i7's start at 4c/8t and already go up to 10c/20t).
The fact that Skylake-X is positioned above Kabylake-X is double bonkers, considering Kaby succeeded Skylake on current platforms.
Naming the new HEDT platform X299 is triple bonkers, as the Z370 mainstream platform will look like the newer, more advanced chipset (Z comes after X, 3 comes after 2 and that's the system the industry has been adopting for years)... This will be even more apparent when someone sees a Kabylake-X i7 as a 4c/4t part, while Coffelake will bring a i7 6c/12t part.
The quadruple bonkers will be when they release pricing info...
__________________
Intel 7600K @ 4.5Ghz - Asus Strix Z270I - Asus Strix GTX 1060 - 16GB HyperX 2400Mhz - Samsung 250GB 960 EVO / 500GB 850 EVO - Corsair AX750 - Phanteks Evolv ITX - Corsair H80i V2
Acer Predator XB240H - Corsair K65 / M65 / Void Wireless / MM300
Wakka is offline   Reply With Quote
Old 15th May 2017, 14:14   #3
Vault-Tec
Green Plastic Watering Can
Vault-Tec's Avatar
Vault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming SaiyanVault-Tec is a Super Spamming Saiyan
Normally I ignore stuff like this. I would ignore this one, but I had an I9 prototype a couple of years back. It was Westmere, and clocked to 1.6ghz. I looked up the ES code and it took me to a Chinese website that called it an I9 prototype. I think it was what they had lined up if Bulldozer was any good. I strongly suspect if it had been then the 980X and 990X etc would have been called I9s and there would have been more of them too (the hex cored chips like).
So this could have credence. Ryzen isn't no Bulldozer, that's for sure.
__________________
He used to do surgery, for girls in the 80s, but gravity always wins...
MUWC Winner ROTT
Vault-Tec is online now   Reply With Quote
Old 15th May 2017, 20:19   #4
IamSoulRider
Minimodder
IamSoulRider has yet to learn the way of the Dremel
Looks like intel is running scared of Whitehaven..
IamSoulRider is offline   Reply With Quote
Old 16th May 2017, 16:59   #5
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
Looks like Intel have rebranded the i7-extreme line as i9, and swapped the i7-extreme name to the new put-a-smaller-core-in-the-big-socket chips. If it weren't for the Kaby Lake cores, this would just be a rebranding exercise.
edzieba is offline   Reply With Quote
Reply
Tags
core i9, cpu, enthusiast, intel, processor, rumour, skylake, skylake-x
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
