Reply
Thread Tools View Mode
Old 16th May 2017, 13:25   #1
mapim
What's a Dremel?
mapim has yet to learn the way of the Dremel
Hi guys this is my first Casecon called Alphatier
I am from germany and all typos ar for your Entertainment XD but i try my best.
The name Alphatier  is because of the two massive Alphacool NexXxoS Monsta 180mm Triple Radiators. They are the biggest Radiators Alphacool offers. I have build the case around them. There is no Case wehre these Monsters fit so i had to build one.
Alphacool Germany and hardwarmax.net helped me out with massively the Watercooling Components so a BIG THANK YOU to them. Without them i would not be able to afford a Projekt like that.
The concept of this whole Build is to create an open unique PC Case that is practical an can handle any Hardware you throw at it.
I just cant see BIG BLACK BOXES anymore.
The goal ist to create a mostly passive ultra silent PC .
I also build the whole thing at home, basically in my room with pretty basic tools and materials that everybody can buy in the local hardware store.
I did this on purpose to inspire people who think they can not do nothing cool because they do not have a whole workshop.
This is how it looks right now but still a lot to do i will update this pic like i progress.
mapim is offline   Reply With Quote
Old 16th May 2017, 15:15   #2
mapim
What's a Dremel?
so lets begin with some Aluminum basic Tools and a Plan.
behold my high-end workbench XD
Old 16th May 2017, 15:21   #3
mapim
What's a Dremel?
behold the mighty Alphacool NexXxoS Monsta 180mm Triple Radiator i added a 120mm Fan for size compression.
U can also see the doner Case for the mainboard tray
Old 16th May 2017, 15:50   #4
mapim
What's a Dremel?
now it ist time to add some profile to the Monster
Old 16th May 2017, 15:54   #5
mapim
What's a Dremel?
The fans are Phobya Phobya G-Silent 18 700rpm Red LED an they dont look that Bad in the Dark. This will also be the outer radiator frame. i do not believe i will need to turn up the fans that often.
Old 16th May 2017, 16:00   #6
mapim
What's a Dremel?
making some more framework
Old 16th May 2017, 18:55   #7
amagriva
Supermodder
amagriva's Avatar
amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.amagriva is definitely a rep cheat.
Nice start but very bad pics format (dimensions...) almost unwatchable and the pics host is engulfed with pop ups and other devilish push commercials (behold the pale sheep german-only speaking...)
amagriva is offline   Reply With Quote
Old 16th May 2017, 20:34   #8
mapim
What's a Dremel?
thanks for the Tipp amagriva i uploadet and resized all the Pics . This buildlog has to be convenient to watch for you guys. I hope it works better now
Old 16th May 2017, 20:35   #9
mapim
What's a Dremel?
So the outer frame is almost done and i have to add some fett of course. So you also get an idea why this is not youre nor normal tower build. And it is huge
Old 17th May 2017, 13:05   #10
mapim
What's a Dremel?
next step will be the Mainboard and Hardware Aera. MB in front res, pump and cabels on the backside
After i pulled the PCI Slots out of the doner Case i had to cut some Aluminum sheet to size that i found on the scrapyard. This will work as the backplate and NT holder
Old 17th May 2017, 13:20   #11
mapim
What's a Dremel?
Mainboard Tray was a pice of work. I build it in a way that it can remove it when i need to. it was al lot of Fidelin around but it worked out quiet well.
Old 17th May 2017, 13:34   #12
mapim
What's a Dremel?
I added some vinyl. I do not like to use Paint. Remember this is all done in the room where i also sleep in
U can also see here how i attached the Hardware aera to the outer radiator frame and wehr the PSU will sit.
Old 18th May 2017, 18:35   #13
mapim
What's a Dremel?
I was not happy with how the Mainboard Backpannel looked an so i did some cuts and foldes and changed the colour to silver for a more uniform look.
Old 19th May 2017, 17:20   #14
mapim
What's a Dremel?
Alphatier is a german Word that describes the BOSS Animal in the Pack ( Alpha-male) . Such a Beast needs some Claws of course. I also made a cross bar. That thing ist really sturdy i was pleasantly surprised how stiff the construction is when the radiators are mounted. OK i already have used over 100 M3 Stainless screws and washers at this point.
Old 20th May 2017, 13:33   #15
mapim
What's a Dremel?
I made a hole in the Mainboardtray. You guys know the drill XD. And i also put some white Vinyl on the MB Tray because the original paint i was not looking that nice anymore.
Old 21st May 2017, 16:43   #16
mapim
What's a Dremel?
While i was cleaning up my current system, i took out my Seasonic Platinum 1200 Watt PSU. Thank God for Modular Cables.
Yes total overklill for my system but i bought it second Hand for a very decent price and could not rissest. I will have to make some holes for better Cable Management over the whole Case. But this ist the PSU that will give the Alphatier the Power that a beast like that needs .
I also made a unboxing Video of the Seasonic Platinum 1200 Watt PSU
Old Yesterday, 13:44   #17
mapim
What's a Dremel?
Now that i test fitted the PSU i can make the cable routing holes. Altough Alphatier will be a reative open Case i still wannt to hide as much cables as i can. I planed a portion on the backside of the MB tray for that. On the backside will be also the positions for the D5 Pump and a small tube-res. But lets see when te watercooling gear arrives.
Reply
Tags
alphacool, casecon, diy, monster radiator, watercooling
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
