Reply
Thread Tools View Mode
Old 17th May 2017, 12:37   #1
fiscalmodding
What's a Dremel?
fiscalmodding's Avatar
fiscalmodding has yet to learn the way of the Dremel
Project Rebellion
Index
1. Introduction
2.Products
3.Design
4. Sponsors
5. Painting
6. Plexiglass cuttings
7. Assembling the modding parts
8. Hardware and watercooling assembling
Introduction
In this modding project I will use the Cooler Master Maker 5 chassis, which I will paint in a dark grey and purple tone. The main material I will use to make the project is plexiglass and in this mod the simplicity and the harmony between the structure of the original chassis and the modifications will predominate. For cooling the hardware I have chosen a custom watercooling solution with rigid tubes and I will include BHcustoms sleeving. The design is inspired by one of the mechas that appear in the Japanese anime Evangelion, the “EVA-01”, and the name “Rebellion” comes from the weapon of a videogame, Devil May Cry.
Products
Design
fiscalmodding is online now   Reply With Quote
Old 17th May 2017, 13:02   #2
fiscalmodding
What's a Dremel?
Sponsors
Painting
Old 17th May 2017, 20:32   #3
fiscalmodding
What's a Dremel?
Plexiglass cuttings
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
