Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th May 2017, 10:28   #1
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
Cooler Master Case Mod World Series 2017 Results
Let's see which modders took the crown(s) in the Cooler Master Case Mod World Series 2017.
https://www.bit-tech.net/modding/eve...2017-results/1
Dogbert666 is offline   Reply With Quote
Old 19th May 2017, 10:50   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
It's definitely the Coolermaster contest that's for sure...
Congrats to all the winners! Quite interesting to see so many familiar faces in the runnings.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 19th May 2017, 11:06   #3
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
..and I was so proud of myself spray painting my case screws gun metal grey.
Hustler is offline   Reply With Quote
Old 19th May 2017, 11:46   #4
davido_labido
Staff
bit-tech Staff
davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.davido_labido is the Cheesecake. Relix smiles down upon them.
You should have entered the competition! I would have voted
davido_labido is offline   Reply With Quote
Old 20th May 2017, 13:34   #5
The_Crapman
Don't phone it's just for fun.
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
So when does a case mod cease to be a case mod? Vega is an amazing peice of craftsmanship for sure, but does putting 1/25th of a case on a scratch build really make it a case mod? Where would you draw the line?
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 21st May 2017, 11:03   #6
davido_labido
Staff
bit-tech Staff
I think whichever way it was done he would get comments about the way it was done. It is not a scratch build either as he uses the CM case (which is pretty prominent at the front of the build)
Old 21st May 2017, 14:06   #7
The_Crapman
I'm sorry but it's most definitely a scratch build. About 98% of it was built from scratch, not even using materials from the case. That's not a case mod.
__________________
Old 21st May 2017, 14:50   #8
davido_labido
Staff
bit-tech Staff
TheIf it was in the scratch build section people would be going 'this is not a scratch build, it clearly has parts from the case'
That is my point, either way it doesn't really fit into the categories.
Old 21st May 2017, 18:27   #9
Maki role
Maki role's Avatar
So what?
I remember this argument used to pop up every year in the MotY contest here, and every year it lead to nothing but bitterness.
__________________
Old 21st May 2017, 21:29   #10
The_Crapman
My point is that it really didn't need that part of the case at all. I'm sure they'd have finished that front bit off just fine without it.
Originally Posted by Maki role View Post
So what?
What's the point in having categories if you just ignore them? Would you allow a horse to race in the 400m at the Olympics? No. Why allow a scratch build in the case mod competition then. Part of the challenge in a case mod is creating something from that form. If I glued a front io panel to my ass would that make it a case mod?
__________________
Old 21st May 2017, 21:45   #11
Maki role
Maki role's Avatar
This is a "Theseus's Ship" problem, so as such it will go nowhere. "Part of the challenge"
__________________
Old 22nd May 2017, 01:26   #12
The_Crapman
Bit like my teeth, not a lot of original material left there either.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
