Other NNNNNNNNNNOOOOOOOOOOOO!!!!!!!!!!! Sickipedia's database may have been lost!
Discussion in 'General' started by Pete J, 11 Feb 2016.
  1. Pete J
    Pete J Employed scum
    28 Sep 2009
    :waah::waah::waah::waah::waah::waah::waah:
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Disk redundancy is not a backup, also 2 backups = 1 back up.
  3. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    This is something I try to get across to people on a daily basis.
    Raid is not a backup.
    Backup to at least 2 places to be on the safe side.
    Bad times for the hosting company
  4. Gareth Halfacree
    4 Dec 2007
    I echo the very excellent sentiments in these replies, along with the classic "a backup isn't a backup until you know you can restore from it."
  5. David
    7 Apr 2009
    Couldn't agree more
    Um.. wut?
  6. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Basically you shouldn't consider yourself to have a backup unless you have a backup of your backup.
    Also that you know that you can restore from it.
    More then once I've seen people say yes we have a backup, which they have but when they try a recovery it fails spectacularly!
  7. David
    7 Apr 2009
    I understand, but that still doesn't mean 2 backups = 1 backup.
    2 Backups is 2 backups. Yes, one might fail on restore but so might both. In which case 2 backups equals no backup. I know that's silly, and less likely, but it's just an extension of what you said.
  8. Kernel
    Kernel Likes cheese
    29 Sep 2003
    True. I think the saying stems more from not to relying on a single point of failure back up. It something I've seen mentioned and I like the ethos of it.
    If one of your backup solutions dies, there is a another to go off. Ideally best practice and due diligence would have these in separate buildings and have disaster recovery test in both, but I know it hard to do sometimes.
    My favourite is when people come in to test infrastructure redundancy by pulling random cables out of servers. :waah: :wallbash:
  9. Edwards
    Edwards Minimodder
    8 Oct 2010
    I always read this as: The first backup is the planned recovery process, the second backup is the backup plan in case the planned recovery fails. There is a certain redundancy to it though, unless you are using a different backup method for the second backup as well as it being stored in a different location.
