Storage HDD controller for RAID
Discussion in 'Hardware' started by Kanutex, 14 Sep 2015.
  1. Kanutex
    Kanutex What's a Dremel?
    12 Jan 2013
    Hi guys, I have 16 x WD NAS Red 4TB Sata 3 and I'd like to do a RAID 5. Which is the best RAID controller for that? Any thoughts? Thanks!
  2. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    Are you planning on running it in a standard case or do you have a case with hot swap backplanes?
    I'd also be pretty nervous if you wanted to make this one big array - either go raid 6 or split it into 2-3 arrays with a shared hot spare.
    Most raid cards have the multi-lane SAS connectors, which you can either break out into 4x SATA/SAS or connect right to a backplane. Some backplanes might also have SAS expanders, which means you might be able to get away with a card having only 2 Multi lane connectors.
    If the data is really important to you, make sure the system is on a UPS that can take the load long enough for a clean shutdown.
  3. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    Obviously it all depends upon budget as to what options there are, as 'the best' is going to be *very* expensive.
    Now, when i was pricing around options for connecting 24-29 drives via SAS in the UK ~6 months ago, it was much cheaper to buy an expander than either a raid card which could do enough drives or a case with an expander backplane.
    So, looking at 'good enough', d.t. cost (plus already owning one of the cards could swap it in 'if' one failed), i bought a 2nd hand 9260-8i for £125 delivered (+ a new BBU separately) - as they're decent cards & i could find nothing comparable for the money...
    (if i'd had a larger budget then, whilst still not 'the best', i would have gone for a 9271-8i - & you don't necessarily *need* an 8i card, so could potentially price on a 4i one instead)
    ...along with a Chenbro CK23601 as an expander (as it better suited my needs both now & if i wanted to slave another one in a 2nd case), but if money's tight then you 'could' read up on the HP 24 port expanders as they're often cheap (less than £100 vs ~£300 new for the Chenbro) on eBay.
    (whilst old this page would be a good starting place - & the most important thing is the f/w it comes with)
    This, however, is just what i chose to do based upon my budget & usage needs - & gives an idea of how i would have altered my spending if there'd been a couple of hundred pounds more or less in my budget at the time.
    Otherwise, it 'should' go without saying that you need to remember that raid is not backup - but as it's not been said yet then just mentioning it so that it's in the thread.
    [Edit]
    Just reread what i'd written, & i am using the original 2960-8i, that i bought in 2009, in another machine - so the bit about swapping in was about there being an advantage for me in having two cards that were compatible with one another, rather than suggesting that you *needed* to have a spare to hand.
  4. Pookeyhead
    30 Jan 2004
    I have the 9260-8i in my server, and it's been brilliant so far.
  5. Xlog
    Xlog Minimodder
    16 Dec 2006
    I'd say go with ZFS(or btrfs if you like experimenting) and RAIDZ2/3, maybe use one hdd as hot spare, RAID5 with 4TB disks (and 16 of them) is just asking for trouble. If you want to stick with hardware raid - at least get a controller supporting raid50/60 (previously mentioned 9260-8i does support it) and use that.
  6. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    mis-post.
