News IBM details 5.2GHz processor
Discussion in 'Article Discussion' started by julieb, 26 Aug 2010.
  1. julieb
    julieb What's a Dremel?
    12 Aug 2010
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I want one >.>
    They look so nice!
  3. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    And it actually won't play Crysis *at all* ;)
  4. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Fixed! :thumb:
  5. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    My big bro works for IBM and probably gets to at least see this kinda stuff in-the-flesh all the time, if not actually use it. I sooo hate him right now....
  6. borandi
    borandi What's a Dremel?
    27 Jan 2010
    Not x86/x64 compatible. Probably be a bitch to write software for it.
  7. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    well if you can get a windows emulator running on it.. it could probably run Crysis in "software" although I guess its been a long time since a game has had that option :rolleyes:
  8. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    POWER 7 is actually pretty nice from the looks of it. They finally changed to an out-of-order execution system, giving a very nice performance boost over POWER 6. They also went with an obscene amount of L3 cache thanks to the use of eDRAM instead of the much larger (physical space-wise) than the SRAM used by Intel and others.
    POWER is also a pretty nice architecture to write software for, especially in comparison with x86/x64. It does have a lot features which would be kind of overkill or useless for a desktop system, though :)
    Also, there are cheaper versions of the POWER 7 available, where cheap means 'only a few multiples of $1,000' :p
  9. Astatine
    Astatine What's a Dremel?
    16 May 2010
    Err, correct me if I'm wrong, but AFAIK this isn't POWER 7. Or indeed POWER at all. It's the Z-Machine, a completely different architecture specifically made for these mainframes. IBM really are mad enough to maintain *two* of their own chip architectures and build small-run, high-cost chips for both...
    Although it shares stuff with the current POWER chips, like the eDRAM cache.
  10. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Wonder if it overclocks ;)
  11. Mister_Tad
    27 Dec 2002
    You really don't.
    Z-Series machines are massive, heavy, power hungry and I'd be impressed if you managed to get through an IPL, let alone do anything on one :D
  12. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    I think I'm well connected......
  13. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    Someone needs to 'somehow' get one of these clock it like mad and do some benchies!
    Few years at the top?
  14. CharlO
    CharlO What's a Dremel?
    21 Oct 2009
    I actually get to play... Wait, I work with one. Believe me, I love my phenom 1055 @ 4.2 twenty times what I aprecciate this machine.
    Aaand besides, it's far from AMD 7.x record...
  15. Mister_Tad
    27 Dec 2002
    I think it needs to be pointed out that THIS is just about as exciting as it gets on these machines.
    Despite what IBM would have you believe with the shiny enclosures - Z/Series is not, and never will be sexy :lol:
  16. Elledan
    4 Feb 2009
    Yeah, you're right: http://en.wikipedia.org/wiki/IBM_z196_(microprocessor)
    I honestly didn't know they actually had a second architecture on active duty :eeek:
  17. liratheal
    20 Nov 2005
    Yeah, but they're pretty! Just because I'd never be able to turn it on, lift it, move it, or use it is irrelevant >.>
  18. Jerz
    Jerz What's a Dremel?
    6 Sep 2006
    When you buy one of these mainframes, do they come with the SDK and support to program on it?
  19. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    I've been working with IBM mainframe for a well known bank for the last 3 months, Z-OS is nasty to use.... but it could churn through data like nobody's business! however glad the project is finished!
  20. [- pio -]
    [- pio -] Minimodder
    2 Feb 2004
    Wow, these machines are beasts! And the redundancy built into the z/Enterprise series is jaw-dropping: Each operation is computed simultaneously by two separate cores, then the results are cross-checked. If they don't match, it tries again, and if it still doesn't work, it automatically sends out a service call so that the IBM guy can come over and hot-swap(!) the processor module without interrupting operations... Even the RAM has a parity table, so the machine can survive the failure of a chip or even an entire memory channel! Of course, the power, cooling and I/O are fully redundant as well. You've gotta love that kind of engineering! (wiki)
    I'd think so, seeing what these things cost.. You can probably get them delivered with software specially tailored for your computational needs, for that matter.
    No, no, no! Just look; you can get ASCII art! :lol:
Tags: Add Tags
