Other Poster fixings
Discussion in 'General' started by Cerberus90, 31 Mar 2012.
  1. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    What can I use to stick my posters up on my wall?
    Blu-tak won't work as they are printed onto silk material stuff.
    I've got some sticky-fixer things, but they leave behind a horrible mess when removed, both on the wall and on the poster. Removing it from the wall is probably easy with some alcohol and a bit of rubbing, but I doubt that'd do the poster any good.
    So, anyone know of anything good, that doesn't leave a mess. I know frames are the best solution, but I can't afford them, and I couldn't find any in 36x13" size.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  3. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    toothpaste
  4. Cerberus90
    23 Apr 2009
    They look interesting.
    How do they work?
    Do the plastic bits 'clip' onto the poster, and then you just hand it like a picture frame with the string?
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Have class, buy a frame!
  6. Cerberus90
    23 Apr 2009
    Too expensive.
    And for this poster, being 36x13 its a weird size so would have to be a custom frame, which would be even more.
    I did look into making my own clip frames. While the MDF backing would be cheap, the perspex front would make it ridiculously expensive.
    My Dads still got three 36x24 pictures that I'd like to get up at some point, a clip frame for that size is ~£12 each at the cheapest, the cost of the three frames would be almost double what the pictures cost.
  7. Smilodon
    25 Mar 2003
    You could use real glass instead of perspex. Should be much cheaper.
    Just make sure that the hanging is solid.
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    That's how it looks to me.
    If the poster has a tendancy to curl you could always stick a couple of pennies to the bottom backside with some magic tape which should ensure they hang straight and flat.
    Magic tape shouldn't damage your poster when the time comes to remove it too.
