Build Advice New Build 2500k
Discussion in 'Hardware' started by psychoti, 6 Mar 2012.
  1. psychoti
    psychoti What's a Dremel?
    6 Mar 2008
    Any suggestions please?
    I havent decide yet on the graphics, but i ll use my old one for few weeks..
  2. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
  3. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    Looks ok. You probably don't need 730W of power though.
  4. psychoti
    6 Mar 2008
    thank you for your replies guys!
    The Zalman case looks nice!i will get it if i go to that shop.
    what would be a good psu for around £70?
    and do you think that i should be looking for a PCI Express 3.0 board?
  5. psychoti
    6 Mar 2008
    i think i finalized my build! :)
  6. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
  7. psychoti
    6 Mar 2008
    i would go for it but i ll get free next day delivery @ ebuyer and modular psu's there, are a bit costly - @ scan they dont have the case i want at the price i want!
    I am hoping that the Fractal Design 3k is going to give enough space to hide many many cables!
  8. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    I would hold fire for ivybridge. they will be the same price as SB afaik but that is a good price for the 2500k.
    Crucial M4 instead of the agility 3? You'll only get the 64gb instead of 90gb for £70ish though.
  9. MightyBenihana
    8 Sep 2011
  10. mikeyandrewb
    mikeyandrewb What's a Dremel?
    31 Oct 2011
    I'd say an M4 as well. Mine is absolutely awesome. Ivy Bridge should be out very soon (hopefully) so I'd wait for that. Is the PSU slightly overpowered??? Otherwise nice spec.
  11. Arednel
    Arednel What's a Dremel?
    13 Oct 2011
    You get free next day delivery from Scan with the number of posts you have, you only need 20 ;)
