Storage SSD advice first timer
Discussion in 'Hardware' started by Carper, 17 Nov 2014.
  1. Carper
    Carper Guru
    19 Aug 2009
    hi guys, looking at buying my first ssd drive for my i5 computer. I have the msi p55-gd65 motherboard so i believe I need a sata 2 drive? not looking at spending more than £150. the ssd will just be used for windows 7 boot up. thanks
  2. mrbungle
    20 Sep 2004
  3. simmo0916
    simmo0916 What's a Dremel?
    25 Nov 2012
    I'm hardly the most technically minded here, But I would suggest looking at the Samsung EVO 840. I just replaced my HD with one, and I'm really pleased with it. Makes a big difference (and I went from an SSD to this new one)
  4. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  5. Carper
    Carper Guru
    19 Aug 2009
    thanks guys will get one ordered tonight as for setting it up Does anyone have any tips? I was going to copy my files to an external drive then format the Hardrive then install the ssd then install windows then just copy my old files onto my old hardrive
  6. johnim40
    johnim40 Minimodder
    23 Apr 2009
    Remember to set the sata in bios to ahci. For the ssd
  7. brave758
    brave758 Minimodder
    16 Apr 2009
    or raid.... if in raid... :)
  8. Mojo
    Mojo Multimodder
    18 Nov 2011
    This but make sure you install the magician software to get the most out of it! :D:thumb:
  9. simmo0916
    25 Nov 2012
    The Magician software makes quite a big difference to be fair.
  10. Carper
    Carper Guru
    19 Aug 2009
  11. hobbs182
    hobbs182 What's a Dremel?
    31 Oct 2014
  12. simmo0916
    25 Nov 2012
    Yup, that's the one I have, and I'm extremely pleased with it.
  13. Fares
    Fares What's a Dremel?
    7 Dec 2008
    Be aware though that the 840 evo has a bug that will slow it down over time as old data adds up .
    You will need to download from the samsung website a tool to repair this issue .
  14. Nexxo
    23 Oct 2001
    Amazon, actually. ;)
    Fares is right: it needs a firmware upgrade to remove the bug. The software to fix it is easy to use and very effective.
  15. hobbs182
    31 Oct 2014
    Dang it, I saw this on hotukdeals but went straight to pcpartpicker to find best price lol
    Nice spot
    Sent from my Nexus 7 using Tapatalk
