Hardware Intel Core i7-4790K (Devil's Canyon) Review
Discussion in 'Article Discussion' started by Dogbert666, 19 Jun 2014.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Maybe my eye site if failing me, but i don't see an AMD FX-9590 in the results.
  4. Harlequin
    Harlequin Modder
    4 Jun 2004
    no but they have an 8350 @ 4.8ghz - my own 9590 is 4.7ghz and 100 points higher
  5. Corky42
    30 Oct 2012
    In R15 they only show results for the 8350 @ 4GHz
    Your screen shot shows the 9590 @ 5.06GHz
    Or am i having a dumb moment here :worried:
  6. Combatus
    16 Feb 2009
    I think there may have been some confusion caused by the fact we listed the overclocked frequencies from our original reviews of the CPUs in the graph too by mistake. We've only tested a select few CPUs at overclocked settings - the rest including the AMD CPU score are from stock speed. I've amended the graph now.
    RE: other AMD CPUs, we're working more closely with AMD about getting hold of their top end chips but when we asked them a year ago for the AMD FX-9590 we were told they weren't sampling them. It's as simple as that.
  7. Harlequin
    Harlequin Modder
    4 Jun 2004
    you can borrow mine if you like ;)
  8. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Seems these chips going by the results from a few sites, don't overclock as high and require higher voltages than the 4770k cpus but give better temps.
  9. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Will still stick with my 2500K at 4ghz with no voltage tweaks. Haven't felt the need to push it any further for gaming at least. Probably different if you're into rendering etc.
  10. Combatus
    16 Feb 2009
    :D Seeing as we usually get comments asking for this I'll drop them a line and see if their tune has changed!
  11. Combatus
    16 Feb 2009
    That's pretty much it. It was quite a bit cooler tbh, and I'm working on getting some water-cooled results as well. But yes, most people I've spoken to from colleagues on other sites to motherboard PRs are hitting a wall at 4.8 with decent air coolers/AIO liquid coolers.
  12. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    Not sure this has the desired gains over my 4770k but its certainly a fast chip at stock! I wonder if deliding to get temps down is on the cards with these chips? Either way, its not a bad chip and certainly not as hot as the previous cpu if 85c is all you saw. Good :)
  13. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    It's a nice boost over the 2500k, but not nice enough to justify both a new processor AND a new motherboard. I can wait for Broadwell.
  14. rollo
    rollo Modder
    16 May 2008
    Can't say I'm shocked by its performance but if I'd of brought a 4770k I'd be not wanting to upgrade. How well it compares to other chips is nigh
  15. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
  16. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Would I be correct in thinking that unless you need the extra cores for whatever reason and if you are mainly gaming then this is not worth the extra money over the i5-4670K/4690K chips?
  17. Panos
    Panos Minimodder
    18 Oct 2006
    I have an 4820K @ 5Ghz. Doubt I will need an upgrade for another 5-6 years. More likely I will replace 2-3 graphic cards until then.
  18. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Only I went from a 2700 to a 4770 so I could keep up with my favourite motherboard the maximus formula
  19. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Why did they release this chip now? Broadwell was supposed to be launched in about 6 months. Are there further delays to Broadwell that haven't been announced yet?
  20. SchizoFrog
    5 May 2009
    As well as my question above, can I ask Bit-Tech if you have an i5-4690K in for review?
Tags: Add Tags
