lian pc 7+ black
Discussion in 'Project Logs' started by kelvan2, 7 Aug 2005.
  1. kelvan2
    kelvan2 What's a Dremel?
    14 May 2005
    got this lian li pc7+black on 30/06
    it came with a front 120mm and rear 80mm fan and got to cut it for 120mm fan
    cut a 8mm acrylic and dirll holes on the side to insert led.
    and there she gose in between the case and the fan
    now the rad is place at the front intake
    and the pump but i place it into the 5.25" bay later cause 1/2 of the bay is empty
    this is the reservior
    it sit on top and it is hidden once all panel is cover
  2. kelvan2
    14 May 2005
    rear view for the resvervior
    cause i use 8mm acrylic for the base of the reservior and can use that same trick to dirll hole on the side and insert LED
    now time for test run and make sure no licking
    now picture on the side panel is decided
    spend more then half a day to cut it out. have you guys notice the cat lost her nose.
    maybe should name this project (M Jackson)
    when shopping with wife and kid and saw this.
    it is handle for sliding windows but i find it just nice for the feet
    so give it a try and add in LED
  3. kelvan2
    14 May 2005
    now some of you might say why this is in ther when no want could see.
    it is some left over 8mm acrylic and find that it is empty up there
    the same old trick is use again drill a hole to insert LED
    add this acrylic to cover those drive bay
  4. kelvan2
    14 May 2005
    this is for all the LED conector
    now i hide all the cable behind the MOBO tray
    now for the power and HDD LED on the front
    ah ha the same old trick
    now i use the USB bay for my power, reset and eject button
  5. kelvan2
    14 May 2005
    ok got to tap the eject button from the cd Rom
    this is all the button
    and the feet with LED
  6. kelvan2
    14 May 2005
    front panel is on
  7. kelvan2
    14 May 2005
    got this thermaltake big water kit cause i find it cheaper then to get a Rad and a water block. l don't like that metal, it makes the water looks cheap so.....
    with the 8mm acrylic left over i give it a try
    now how is this ? better right?
  8. kelvan2
    14 May 2005
  9. kelvan2
    14 May 2005
  10. kelvan2
    14 May 2005
  11. kelvan2
    14 May 2005
  12. kelvan2
    14 May 2005
    fan speed control into the keyboard
    now this rig is sitting on the floor and it is hard for me the control the speed of the fan so add the fan speed controller in to the keyboard
    cut and file for it to go right in
    the rear view
    cut a rubber easier to support so it will not fall back in to the KB
    and it is done
    now thank you for reading my mod.
    it took me a month finish this mod.
    and lots of idea came from this fourm from some better modder here.
    been around here for few month and love it here.
    once agian thank you.
    (sorry for my bad english)
  13. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    Nice, in the second picture tho, the fan doesnt seem to line up. Also some words would be nice.
  14. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Very nicely done! I like it!!
  15. Hal
    Hal What's a Dremel?
    1 Feb 2005
    wow... a super plethora of pictures! its like a silent movie! wow. i love it. i love the "sam" and the front bezel. wow... how long did this take? i also like how the panther? vut out on the side is bare metal on the sides of the cuts due to the cuts. it gives it depth! wow again.
  16. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    what does the twisty knob on the keyboard do?
  17. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    It's a shame the "SAM" plexi LED-lit lettering is hidden when the side panel is on, but sweet Thundercat! :)
  18. roachm
    roachm What's a Dremel?
    16 Nov 2004
    Your taste is similar to mine, and you did an AMAZING job with this project, Iove it.
  19. invalid
    invalid What's a Dremel?
    23 Jan 2005
    I am liking it. The only thing I don't understand is doing that awesome SAM lettering and have it not be visible. How often is the side of the case off?
  20. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    Very, very nice. I love the window cutout, nice and clean, and very cool design.
