Motherboards Do you update your bios?
Discussion in 'Hardware' started by crispy, 6 Nov 2008.
  1. Always, part of the pc build
    37.6%
  2. Only to correct a problem
    53.2%
  3. Never, not going to risk it
    9.2%
  1. crispy
    crispy What's a Dremel?
    29 Aug 2008
    Just wondering after reading another post.
    I seldom update the bios on cheap builds for friends. However, I do update the bios on my primary pc within the first week of building it, once I know everything is working.
  2. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    I usually only update fix problems, but now that most manufacturers have tools that make it easy I tend to update more often.
  3. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    I do it when i build a new rig. Then I'll do it to fix issues i suspect a bios update may fix. Other then that I rarely update.
    Don't really believe that it's a risk.
  4. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I never have and never intend too, I don't want to brick my nice expensive mobos :X
  5. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Successfully managed to kill my BIOS during flashing it to an earlier version.
    That's £10 I won't see again. :duh:
  6. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I always update, especially if it's an expensive mobo
  7. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    I should do it more often... there is the occasional performance gain at time i guess.
    Updated an old one ages ago, brought the boot time down significantly.
  8. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    no, but i really need to. my current bios are limiting my fancy ddr3 1333 to 800mhz
  9. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Not really worth the hassle unless a newer bios has some nifty stuff to it. Only updated this current mobo once - and the new bios clocks so much better ;)
  10. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Updating a BIOS isn't that much of a risk... but I avoid it usually because my motherboard is a bit problematic -an EVGA 680i (A1). I've had plenty of problems before, but the current config seems fine, so I'll leave it alone...
    My cousin has an Asus board and I update his when I get a chance because the newer ones are guaranteed to fix something. Plus if it breaks, its not my computer :p
    I usually look at updating if I get some new hardware in there...
  11. Ninja_182
    Ninja_182 Enginerd!
    2 Apr 2002
    Usually update on a new build if theres one available but I dont keep it updated mainly because I never hear anything about updates being released and its not high on my list of interests
  12. Daveofthedead
    Daveofthedead What's a Dremel?
    29 Dec 2007
    i update now a lot more to fix problem. but i never use to be coz of the risk but u don't have to worry to much now about that :)
  13. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I think you'd have to be a real tool to irreversibly damage your board by updating the BIOS. It's not exactly ground-shaking stuff, and you can always clear the CMOS if it goes wrong.
    Can be useful to get additional settings and options that aren't available in the vanilla BIOS - there are usually a few. Also helpful if a bit of hardware gets what I like to call 'haunted' - i.e. it refuses to work in the motherboard despite both being functional and compatible.
  14. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Always. Updating the BIOS unlocks the full potential of this board... :D
    Having said that I haven't updated the BIOS since 2006, but hey the board is getting on a bit. :p
  15. Matticus
    Matticus ...
    23 Feb 2008
    When I got my board I needed to update so it would work fully with my wolfdale, even though it seemed ok before the update. I had heard of issues so I thought I would catch them out before they appear for me.
    I then updated through about 4 flavours of the new beta bios and am now on the released version of this bios.
    There is a new beta out which temps me, as I know that each beta seemed to change around the bios a bit or add a new function.
  16. ComputerKing
    8 Sep 2006
    I update when Find a new bios on the company site :) using @bios ;)
  17. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    unless theres an express problem i generally dont bother. a working pc is more important to me than a completely up to date one
  18. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    no f'ing clevo has never released an update EVER for 3yr old laptop
  19. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Only if there's a problem OOTB that is solved in a later bios revision, or if the OOTB bios doesn't support the CPU officially (IE: My gigabyte supposedly didn't support the 9950 until revision F5, but it was working fine on F3) for the sake of tech support calls, if there are any.
    Most of the time I don't bother - If it ain't broke, don't fix it. Or so they say.
  20. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    I went for only to correct a problem, but I'm with modgodtanvir on this. I've got an A1 680i, and after the hastle of making it work, the bios it has now is the one its sticking with! Back in the days of the Socket A LanParty boards I went through pretty much every bios out there in the hunt for more clockspeed though.
    RwD
