Watercooling Alpine White TJ07- Water Cooled - Pictures
Discussion in 'Hardware' started by bdigital, 9 Sep 2012.
  1. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hi everyone,
    A few months back i set out to refine and improve my white TJ07 build, and it is finally done.
    The change list was small, but significant in terms of impact and performace:
    - Modify Asus Sabertooth Thermal armour to take a waterblock :dremel:
    - Spray everything in correct colour theme (including thermal armour and my GT 1450s!)
    - Upgrade from moderate overclocking 2500k to good clocking 2600k
    - Upgrade to quad rad instead of triple
    - New mid plate, internal fan plate and side mounted fan controller drawn in cad and laser cut for accuracy and professional look
    - Upgrade from GTX 480 to 7970
    - Make custom GPU backplate with my snowflake from the last build
    - Custom sleeved PSU cables
    - New D5 pump
    - New acrylic EK CPU block
    - New USB 3 and card reader front bay
    - Side mounted drive bay, giving access to HDD and SSDs from side panel :dremel:
    - New Motherboard tray with medusa design instead of redundant fan mounts
    I really wish i had done a work log :(
    Anyway, i should say thanks to many of you on here for help and advice on the way. Theres too many to list, but i would like to say a special thank you to Paz45, Big Elf and 23RO_UK - I am so appreciative of your time and assistance :thumb:
    Please excuse some of the pictures as I am still learning, but I intend to take some more (read better) snaps when i get the chance.
    Happy to post up some benchies if anyone is interested.
    Untitled by bdigital101, on Flickr
    IMG_6233 by bdigital101, on Flickr
    IMG_6218 by bdigital101, on Flickr
    IMG_6257 by bdigital101, on Flickr
    IMG_6258 by bdigital101, on Flickr
    IMG_6266 by bdigital101, on Flickr
    IMG_6222 by bdigital101, on Flickr
    adidan, David, G0UDG and 1 other person like this.
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    I like the top window!
    Any more details on what you did with the mobo exactly? Curious about the tray as well.
  3. Guest-44432
    Guest-44432 Guest
    Top job on your build! Looks absolutely awesome! Me want!! :)
    Teelzebub and David like this.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Amazing!
    Teelzebub likes this.
  5. bdigital
    10 Aug 2010
    Bascially your not supposed to be able to fit the waterblock AND the thermal armour together - So i got out the pencil, ruler, clamps and dremel and made it fit!! :dremel:
    Then I sprayed it along with my GT 1450 fans
  6. David
    7 Apr 2009
    Lovely job, Bobby.
    Is that a Zalman ZM-MFC1 fan controller on the side? Just wondering if you modded the LEDs on it.
    Teelzebub and YEHBABY like this.
  7. bdigital
    10 Aug 2010
    Yes it is matey - Didnt mod the LEDs, although i may do. Bit of a long story but this particular model turns the LED red when the fan is anything higher than the lowest voltage.
    May not sound like a problem to a normal person, but considering ive just spend the last couple of months making sure everything was white or blue its a bit annoying!!!!
    Thanks for the comments though. Theres more pics in my profile album or on my flickr. :thumb:
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    That is such a lovely clean build and your photography skills are damn fine too.
  9. Big Elf
    23 Apr 2009
    Been waiting for the piccies for ages. Very impressed with the finished result, you built a classy system.
  10. bdigital
    10 Aug 2010
    Thanks Big Elf - you were a big part of it and im very grateful for all your help.
  11. Guest-56605
    Guest-56605 Guest
    You've truly outdone yourself on that Bobby!!! :D
    Nothing looks better than a well thought out clean TJ07 and that is up there with the best of them mate; the thought and effort you've put into the rebuild is readily apparent and it works so so well :thumb:
    Absolutely f*cking superb :clap: :rock:
    +rep beyond any doubt
  12. bdigital
    10 Aug 2010
    Thank you Paul. Coming from you, that means a great deal to me :)
    As always there are a few things to fine tune and i need to take a few more shots of the whole case.
    Guest-56605 and N17 dizzi like this.
  13. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Amazing Bobby, really nice :)
    + rep
  14. Guest-56605
    Guest-56605 Guest
    Credit where credit is due mate :thumb:
    Ps. Nice CPU block ;) :D
  15. bdigital
    10 Aug 2010
    Hehe told u i had plans for it one day! Top bit of kit from you as always.
    Although i want some of the rounded thumb nuts rather than the disc ones, just for cosmetic reasons of course
  16. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    I'm mighty impressed :thumb:
    Amazing work.
  17. Guest-56605
    Guest-56605 Guest
    Drop me a PM with your home address and I'll have some on there way to you tomorrow :thumb:
    (I had an inbox clearout and went overboard :duh:)
  18. bdigital
    10 Aug 2010
    Done lol. There you go again with the excellent customer service and help! Will rep you up when im on my pc.
  19. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Very very nice mate. Looks so neat and clean
  20. Big Elf
    23 Apr 2009
    I think I've got some M4 white nylon dome nuts that would fit on the end of the CPU block clamps.
    Edit: They're not white, more of a natural colour like the wire housings
