Storage Synology NAS installation corrupt
Discussion in 'Tech Support' started by Zehetmayr, 4 Mar 2017.
  1. Zehetmayr
    Zehetmayr Minimodder
    23 Apr 2011
    Hi All, I've posted this on the Synology forums but it can't hurt to post it here as well. Thanks everyone.
    "my brother's DS212J is claiming that DSM isn't installed following a house move. My only guess is that the installation has become corrupt? I am looking to reinstall DSM but don't want to lose the data on the drives (Raid1). I was going down the safe option and trying to backup the data before running an installation as Synology Assistant claims "you will lose all your data" etc. I've removed a hard drive and have connected it to a W10 PC. Drive Management can see the hard drive but I was unable to assign a drive letter to actually view the files. I then used EX2 Volume Manager which allowed me to assign a letter and view the file structure. I'm a bit lost from here. I can't see anywhere obvious that the files are stored. Can a backup be done this way or am I barking up the wrong tree? Could someone point me in the right direction? I don't have access to a linux system. Any help much appreciated. Cheers, Will."
  2. faugusztin
    11 Aug 2008
    Synology DSM has Linux LVM on top of Linux mdraid. So you need Linux ideally.
    RAID arrays on my DS216j :
    Code:
    # cat /proc/mdstat
    Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
    md2 : active raid1 sda5[0] sdb5[1]
          3902187456 blocks super 1.2 [2/2] [UU]
    md1 : active raid1 sda2[0] sdb2[1]
          2097088 blocks [2/2] [UU]
    md0 : active raid1 sda1[0] sdb1[1]
          2490176 blocks [2/2] [UU]
    Which then maps to LVM physical volume :
    Code:
    #pvdisplay
      --- Physical volume ---
      PV Name               /dev/md2
      VG Name               vg1000
      PV Size               3.63 TiB / not usable 1.94 MiB
      Allocatable           yes (but full)
      PE Size               4.00 MiB
      Total PE              952682
      Free PE               0
      Allocated PE          952682
      PV UUID               crypticID
    Which then maps to LVM volume group :
    Code:
    # vgdisplay
      --- Volume group ---
      VG Name               vg1000
      System ID
      Format                lvm2
      Metadata Areas        1
      Metadata Sequence No  2
      VG Access             read/write
      VG Status             resizable
      MAX LV                0
      Cur LV                1
      Open LV               1
      Max PV                0
      Cur PV                1
      Act PV                1
      VG Size               3.63 TiB
      PE Size               4.00 MiB
      Total PE              952682
      Alloc PE / Size       952682 / 3.63 TiB
      Free  PE / Size       0 / 0
      VG UUID               anotherCrypticID
    Which then finally maps to LVM logical volume :
    Code:
    # lvdisplay
      --- Logical volume ---
      LV Path                /dev/vg1000/lv
      LV Name                lv
      VG Name                vg1000
      LV UUID                lastCrypticID
      LV Write Access        read/write
      LV Creation host, time ,
      LV Status              available
      # open                 1
      LV Size                3.63 TiB
      Current LE             952682
      Segments               1
      Allocation             inherit
      Read ahead sectors     auto
      - currently set to     512
      Block device           253:0
    And this logical volume is then mapped to /volumeNumber in the filesystem :
    Code:
    /dev/mapper/vg1000-lv on /volume1 type ext4 (rw,relatime,journal_checksum,synoacl,data=writeback,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group)
    So if you managed to get around this in Windows, good for you - and at this moment you should see the folders for shares he defined, plus few folders and files with @ in front of them - like @eaDir, @iSCSI, @appstore etc. His files should be in the non-@ folders.
    If you see something else (like folders bin,dev, etc,root,usr and so on), you mounted /dev/md0, which is the system ext4 RAID1 partition - you are not interested in this one. There is also /dev/md1, which is the swap partition.
    Official guide to recovery using Ubuntu : https://www.synology.com/en-global/...I_recover_data_from_my_DiskStation_using_a_PC
  3. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    I know it sound silly but did you check the drives?
    We get this all the time with these units, even just taking on our selves up the road to a customer (not even posting) the drive came loose and corrupted the OS.
    Norm just get the end user to reseat all the drives, reboot and it comes back.
