Electronics Custom cables orientation
Discussion in 'Modding' started by Maarten/Pine, 9 Apr 2017.
  1. Maarten/Pine
    Maarten/Pine Case modder
    10 Mar 2017
    Hi guys,
    I'm working on a project where I will make a set of custom cables (no extensions). The cables I will be using won't have a sleeve, they just have a copper core with transparent insulation.
    Copper wire area is 1.5mm^2, which is just a little thicker than 16AWG. Already tried to crimp it, works fine.
    This weekend I made a full pinout of the RM850i (the PSU that's used) for all the cables with a multimeter.
    Now that I want to start with making the cables, I have some questions.
    The 24-pin has quite alot of twin cables. If the mobo-side has a single 12V, does it matter where you attach the double wires on the PSU side? of course they should be 12V, but does it matter which port, they're all on the same 12V rail right?
    Furthermore, on the 8pin pcie at the psu side, there is a wire that's not used. How can I best make a dummy wire?
    On the 8pin pcie at the gpu side, there is also an extra ground cable. Ground cables can also be splitted, right?
    Thanks alot in advance!!
  2. TheMadDutchDude
    23 Aug 2013
    It won't matter which 12v pin out of the PSU is used from what I can gather. :)
    Grounding cables can be split, yes. Just don't split them into 50 wires. :D
  3. Maarten/Pine
    10 Mar 2017
    Thanks for the reply and answers mate!
    Any idea on how to best make a dummy wire when not working with cable sleeve?
  4. Big Elf
    23 Apr 2009
    Splice the 'dummy' wire onto the outside of another using either heatshrink or maybe try superglue although I'm not convinced that would hold.
    Post #9 is how I do it albeit with sleeved wires.
  5. Maarten/Pine
    10 Mar 2017
    Thanks very much to both of you! Definitely helped me.
