Apple Failed Message
Discussion in 'Tech Support' started by goldstar0011, 22 May 2017.
  1. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Am helping a colleague with an iPhone issue.
    Messages to hiss daughters iPhone aren't going through as an imessage or text message.
    I have deleted the contact and using just the number, I have toggled the imessage off and on but still just fails.
    Who's phone is at fault and what checks can I do
    Cheers
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    if even an sms is not being delivered surely the number has been barred or something? Did you check on the contact when it was on the phone to make sure it wasn't blocked
  3. goldstar0011
    2 Sep 2007
    I'll get the guy to check his daughters phone just in case, cheers
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    See if you can phone them, the network might give you a message indicating the problem.
  5. goldstar0011
    2 Sep 2007
    Well calls to her number are fine so won't be blocked
  6. wyx087
    15 Aug 2007
    Try turning off iMessage on both devices and then send a normal SMS (green bubble). It should go through no problem if network hasn't put in any blockage.
    Can you send other people iMessages? I suspect it's the receiving device at fault.
  7. goldstar0011
    2 Sep 2007
    Others receive imessages all ok, I suspect the same so have been trying to prove that with looking at his device
  8. wyx087
    15 Aug 2007
    Also try send imseesage to receiver's Apple ID Email address. I've found sometimes imessage doesn't pick up the phone number.
  9. Margo Baggins
    28 May 2010
    I had a weird thing once where I had someones contact saved twice so when they imessaged me etc. it started coming from their email address not their phone number - it's not something weird like that?
  10. goldstar0011
    2 Sep 2007
    I don't think so, I went through his contacts to check for duplicated or an error in the details bit nothing, I've asked to bring his kids phone in, has anyone tried taking a phone from a 15 year old girl!!!
