Other best free pc protection
Discussion in 'Software' started by nescafe, 24 May 2017.
  1. nescafe
    nescafe Minimodder
    8 Sep 2009
    Hiya all. Just done a clean install of windows and just about to install avg free as i usually do but wondering if there are any better free protection out there? Im a bit out of touch with it all now. lol
  2. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I build quite a few systems in all budgets and personally unless instructed otherwise I just use windows defender, it just works, the customers don't need to touch it. I advise them to not visit dodgy websites and click dodgy links and so far I've had no issues.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    If no one is clicking dodgy links and stuff, anti virus would be almost redundant ;) but I see your point, for those who know what they're doing, there's no need for anything else.
    If you absolutely have to have something else, I'd go for Bitdefender Free. AVG is complete rubbish recently.
  4. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    Avira and Malwarebytes
    Sent from my LG-H850 using Tapatalk
  5. wolfticket
    19 Apr 2008
    I've been using Avira Free for ages. I like it and last I looked it performs pretty well in tests.
  6. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    I've always been very happy with Microsoft Security Essentials to be fair. It sits there, does what it needs to do and doesn't bother me. If you buy something like Norton or whatever then go and hang your head in shame.
  7. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Windows defender, just don't visit dodgy sites. Job done.
  8. creative
    creative 500rwhp
    23 May 2014
    avg free is popup heaven now. I used it for years and its now removed.
    Been trying out Panda Free. Seems to work. You can also turn off any advertising in the settings and I compliment that with Malwarebytes
  9. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    I run Sophos home edition which is web managed and free for up to 10 computers I think
  10. Lorenzmoll
    Lorenzmoll What's a Dremel?
    29 May 2017
    Totally agree with previous posters. The best free pc protection is common sense:) However if you must have some outside protection, there's a ton of resources on this. Avast and Avira are quite good pieces of software for the money. Check them out first.
  11. Bazz
    Bazz Multimodder
    7 Oct 2009
    Just started using this, seems to be really good.
  12. nimbu
    nimbu Multimodder
    28 Nov 2002
    Have also been using this for about a year I think. Have it on my parents computers so I can keep an eye.
  13. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    I use it on a couple friends pcs means I don't even have to walk them through opening teamviewer ..."what's the start button" ...
  14. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Linux.
  15. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    Just read this morning that Kaspersky are launching a free AV product - launching in the US in the next 24 hours, launching in the UK in October. No idea if it's any good but the AV tests over on PC Pro usually put Kaspersky at the top of the pile in AV roundup testing for detection. Comes with no ads either, but Kaspersky will use data for machine learning - make of that what you want.
    tbh AVG has too many ads these days and I'm happy using Windows Defender (even if the detection rate isn't fantastic) and Malewarebytes free to cover everything.
  16. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    +1 for Avira. Plus their scanner is called Luke Filewalker so bonus geek points for them :)
  17. cloudkristen
    cloudkristen What's a Dremel?
    29 Nov 2016
    Thank you all
  18. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Bit defender <3
  19. stellakelly
    stellakelly What's a Dremel?
    17 Sep 2017
    What I believe is ad what i am doing is as follows for my system.
    1. I never use pendrives to my system from other systems.
    2. I am satisfied with Windows even windows also provide security to my system like windows defender
    3. I can update my system on regular basis
    I think that Antiviruses slow down system and make work difficult.
