Case Mod - In Progress Build Log "45Deg"
Discussion in 'Project Logs' started by kryptekPCmodz, 30 Dec 2015.
  1. kryptekPCmodz
    kryptekPCmodz What's a Dremel?
    16 Dec 2015
    Hello, my name is DJ Madrid age of 21 and also known as Kryptek PC Casemodz, I am from the Philippines. And also, thanks to my major sponsor for this build project Thermaltake and ASUS, thank you so much for this opportunity, more power!
    And now, let's go to the build.
    This project will be named "45Deg" or "45 Degree", the position of the motherboard is something new in our eyes because normally many of the mods today are rotated into 90 degree or 180 degree inverted, so I decided to make a 45 degree rotated motherboard position. I'll be using Thermaltakes water cooling parts, case, power supply and Riing fans, Asus motherboard, GPU and etc.
    Here is my isometric 3D design using Google SketchUp 2016. Hope you'll like it
  2. Shirty
    18 Apr 1982
    Welcome to the forums! Do you have any work in progress to upload at this stage? I've temporarily moved the thread to modding until you can confirm.
    Thanks!
  3. kryptekPCmodz
    16 Dec 2015
    Thank you! Yes, I have my work on going, I'll upload it later :cooldude:
  4. kryptekPCmodz
    16 Dec 2015
    Hey guys! Late update, these are the items from Thermaltake's i'll be using for this build. :cooldude:
  5. kryptekPCmodz
    16 Dec 2015
    Got them shot! These are awesome, many thanks to @Thermaltake Technology Inc for supporting me! :clap:
  6. kryptekPCmodz
    16 Dec 2015
    Hey guys! Sorry for the late update, I changed a little design of my isometric design and now on i'll start stripping this case and lets start it!
  7. Shirty
    18 Apr 1982
    Moved back to build logs - good luck :)
  8. kryptekPCmodz
    16 Dec 2015
    Thank you! :rock:
  9. kryptekPCmodz
    16 Dec 2015
    Ok, I just dis-assembled the top and rear panel for now.
  10. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Like the idea of a 45 degree angle.
  11. kryptekPCmodz
    16 Dec 2015
    Thank you mate! :dremel:
  12. kryptekPCmodz
    16 Dec 2015
    Good afternoon guys! Just a little update of the case, I made the frame using angle bar aluminum steel.
  13. kryptekPCmodz
    16 Dec 2015
    Before we resume modding, let me do a quick preview of the motherboard that i'll be using for the build ;)
    The sexy main board
    Sexy heatsink, I loved it! Also you're gonna use only the Skylake processors with DDR4 3400+ MHz (OC) 4 DIMM slots, dual Channel XMP Support
    SupremeFX on-board audio, the best audio performance
    PCI Express slot, and also have the M.2 Socket 3 Type M PCIe Gen 3.0 x4
    southbridge heatsink with the ROG logo is more sexier than the previous rog boards ;)
    IO ports
  14. kryptekPCmodz
    16 Dec 2015
    For now, just to preview this gpu from Asus the GTX 970 Strix 4GB. Unfortunately I got fever and headache in the past few days so that I cannot updated some modding works today, I just took a photos for a quick update, hope you guys understand. I'll keep you guys updated!
  15. Cheapskate
    13 May 2007
    Design looks promising.:D Is it not too late to add a small forward tilt on the face? It will make it look "fast".;)
  16. kryptekPCmodz
    16 Dec 2015
    Hey! How you guys doing?
    Im just living here a quick update of the hardware part which is the Raiden-Red Tesla for Avexir that i'll be using for the build.
    Here we go!
    I'll update the build asap!
  17. kryptekPCmodz
    16 Dec 2015
    Hey guys! Sorry for the late update, I got the aluminum sheet for motherboard tray
    Ongoing...
  18. kryptekPCmodz
    16 Dec 2015
    Motherboard tray test fit...
    need to buy more 90degree aluminum bar for the motherboard tray
  19. kryptekPCmodz
    16 Dec 2015
    Today's update!
    Need to cut more aluminum bar for the motherboard tray.
    Testing 123 :D
    There it is... got a 3mm allen bolt to bond each other.. :D
    Ok, and that's it for today :D
  20. kryptekPCmodz
    16 Dec 2015
    Ok got the SSD, thank you so much OCZ Storage Solutions for this support!
