Build Advice Haswell build check
Discussion in 'Hardware' started by Shadow_101, 27 Aug 2013.
  1. Shadow_101
    Shadow_101 Minimodder
    12 Feb 2004
    Hey Folks,
    Haven’t done a new build in a while* and would appreciate some criticism/advice :)
    Budget: Not really set out with one, just after a good workhorse for a reasonable price.
    Use: Some Gaming, quite a bit of VM work, will be overclocked.
    Not that convinced I’ll bother with the 1TB hard drive, and may swap it with a larger Samsung SSD, as I’ve got 4TB of network storage for anything long term.
    Also R3 case has noise padding not sure how well that will play with the hot Haswell’s when overclocked?
    Matt
    *my last build may have been Athon 64..., 2005?
  2. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Id be tempted to up the SSD to the 250GB model but other than that nice looking build.
    Shadow_101 likes this.
  3. Shadow_101
    12 Feb 2004
    Cheers MrGumby.
    With 137 views and one comment I’ll assume there’s nothing glaringly wrong with the build.
    Thanks,
  4. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    I can't help but feel you have skimped on the cooler. The CPU you've got runs bloody hot so I would consider a H80/Kuhler 920/H100 or even one of these as they're pretty cheap right now.
    http://www.scan.co.uk/products/cors...-2xfans-intel-lga-115x-1366-2011-amd-am2(plus)
    Ooo ! nice they have those back in stock !! I was gonna post this..
    http://www.scan.co.uk/products/ener...uble-length-radiator-2-x-tb-silence-12cm-fans
    But yeah, definitely worth the extra beans IMO.
    Edit for some reason that top link will not work when pasted.. Go to coolers - water - multi cpu hyrdo coolers..
    Or scan product number LN51721
    It's a refurb H80 for £37.
  5. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    The build looks good to me. You could consider a better cooler but I personally would avoid the refurb all-in-one coolers. I have a H60 on my 3570K and it does a damn fine job whilst OC'd to 4.6GHz.
    I would also consider a 250GB SSD too.
  6. AlienwareAndy
    7 Dec 2009
    Is there a reason for that? I've had mine for months now and not a single problem.
