Watercooling Recommend me some tubing
Discussion in 'Hardware' started by N17 dizzi, 22 Jun 2012.
  1. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    My Tygon R3603 has plasticized like mad and I hate the shade it turns my lovely red coolant from Mayhems.
    When the 670 blocks arrive (now available on pre order) I will rip it out and start again. I've looked at several threads on other forums and all are suggesting there is no non cloudy/discolouring tubing available currently.
    I throw it to the bit community, anyone got any suggestions for decent 1/2" ID clear tubing that hasn't got a clouding or discolour issue? Or even a nice coloured tubing that will match Mayhems red X1?
    Cheers
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Hmmm il find out what stuff im using as it hasnt clouded.
    Having said that ive never left tubing or water in my rig longer than 6 months before replacing. So it might not be long enough to see those effects anyway?
  3. N17 dizzi
    23 Mar 2011
    I allowed my coolant to warm to about 40c testing unaware that this tubing is suseptible to plasticzing at warmer temps and it now looks horrible.
    Mayhems has a thread about it at overclockers.net
    I've heard that Primochill LRT has changed and is now not very good or there is a large dodgy batch? Again this I got from another forum.
    Any help would be appreciated :)
  4. Big Elf
    23 Apr 2009
    I've never had clouding with Primochill and that includes new batches. However my water temps don't go more than 5-6ºC above ambient, so typically around 25ºC rising to perhaps 35ºC if the ambient temps get really hot which might explain it. I've been following Mayhem's thread with interest.
    Edit: Some people have reported clouding after as little as a few hours.
  5. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    So does this affect primochill tubing? Also does it effect thermal performance?
    EDIT: sorry just read big elf's post, so it usually occurs above 40c I guess
  6. Parge
    16 Jul 2010
    Jeeze. My water temps hover at 38C and go up to about 57C in gaming (I blame the 480's).
    I have TFC stuff, its blue in colour but so far I haven't seen any changes and am very happy with it.
  7. Big Elf
    23 Apr 2009
    It can have an indirect effect on your loop. Depending on the block construction the plasticiser can gunk up the pins and eventually affect the flow rate.
    I have a couple of small lengths of clear soft Clearflex in my loop to help decouple the pumps. Those bits of tubing are white now and I removed a fair bit of the plasticiser gunk from my CPU block as the flow rate had almost stopped. I'd got lazy and hadn't checked the block for over a year which is why it built up so much.
    I never had any problems with TFC tubing either but prefer Primochill as it's a bit softer and bends a bit better.
  8. icemanTM
    icemanTM What's a Dremel?
    16 Jun 2012
    Newer versions of Primochill Pro LRT is serving quiet good for me :)
  9. The_Crapman
    5 Dec 2011
    Does anyone know what acrylic tubing is like long term?
  10. Big Elf
    23 Apr 2009
    I've been using Bitspower Crystal Links for over a year and they still look the same as when I put them in.
  11. The_Crapman
    5 Dec 2011
  12. The_Crapman
    5 Dec 2011
    Dp
  13. N17 dizzi
    23 Mar 2011
  14. The_Crapman
    5 Dec 2011
    Not buying it till monday, but I'll take a snip off one when they arrive and let you know. Although come to think of it, what would be the best saw? I think I might have to bring the junior hacksaw out of retirement. Smaller teeth should mean cleaner cut.
    EDIT: bit silly having to order 10m at a time. BUT, they're only 15 mins from where I live, so could see if they'll do less for collection, then I can chop it into smaller sections and post it to you.
  15. Big Elf
    23 Apr 2009
    OK, now I'm curious. How are you going to use these?
  16. The_Crapman
    5 Dec 2011
    Sorry, what do you mean? Do you mean how will I attach them to the res, pumps etc? If that what you mean then I'll be using compression fittings.
  17. Big Elf
    23 Apr 2009
    It's rigid tube, compressions won't work. Multi link adapters will like this will as long as you're using straight lines and the ports line up exactly.
    Edit: Just to add that the multi link adapters fit 12mm OD tubing only.
  18. N17 dizzi
    23 Mar 2011
    I've got a D plug that might work but its still limited by the OD and straight lines
    edit - no it won't, o rings are on the male end
  19. The_Crapman
    5 Dec 2011
    i know it wont be that simple, but with a bit of sanding, ok LOTS of sanding and some ptfe tape i'm sure i can get it to work.
  20. Big Elf
    23 Apr 2009
    I still think you'd need multi-link adapters and exactly straight connections unless it's possible to bend acrylic tubing without distortion. The rigid tubing I've seen has used copper and either the multi-link adapters or flanged connectors.
