Watercooling asrock z77 waterbloacks
Discussion in 'Hardware' started by bluc, 23 Jun 2012.
  1. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Anybody know of water blocks for the z77 extreme 6 asrock motherboard? Full cover or universal also need mofset blocks cheers
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
  3. bluc
    4 Apr 2012
    Ek have a universal block that will fit the soutbride so that's taken care of :). So the area around CPU is mofsets correct? What blocks suit these or are they a universal fit ek have no plans to make one. Sorry for newbie questions first attempt at water cooling.
  4. Bloody_Pete
    11 Aug 2008
    What are you watercooling your motherboard? They run very cool...
  5. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    No the southbridge is the heat sink near the PCI(-E) slots, they really run cool so no need to water cool that.
    If you want to water cool your motherboard cool the mosfets, VRMs and northbridge, they are around your CPU
  6. bluc
    4 Apr 2012
    Mofset run parellel to top of board directly above CPU socket correct? Guessing vrm runs down left side of CPU? Does the z77 not have a north bridge? Trying to find blocks that will fit is a real pita.
  7. Bladesingerz
    30 Nov 2011
    VRMs & mosfets are (most of the times) grouped together, infront of each other or next to each other. But yes, around the CPU.
    The northbridge is also near the VRM & mosfets, most commonly placed between the VRM/mosfets and 1th PCI(-E) slot, if you remove the heat sink from the your motherboard you'll problely see it instantly.
    Heres a small picture on a old motherboard :)
  8. bluc
    4 Apr 2012
    Yea that is where I thought the northbridge was. Here is a picture of my board
    does not appear to have a northbridge. But as long as I can find the needed waterblock will cool the mofset/vrm and ram in same loop.
  9. Bloody_Pete
    11 Aug 2008
    The northbridge and southbridge don't technically exist anymore as 90% of the I/O is built into the CPI. There is a semi-southbridge with deals with extra SATA ports and USB and such.
    Either way, on a Z77 board they run so cool that watercooling them is just a pointless waste of money. Don't bother, as it wont help you OC any better and all it will do it add extra restriction to your loop. Just do CPU and GPU and have a fan blowing near the motherboard and you'll be set.
